Pulsar digital watch Y799-5039
By luiazazrambo · Posted
By LittleWatchShop · Posted
I am an amateur, so there's that. I do not get fixated on amplitude, lift angles, and beat error. However, 4.8ms would bug me if it were my watch. But you must judge your own skills to appreciate the possibility of going backward. I suggest, that you button it up let your friend enjoy the watch for now. As your skills progress, come back to it and correct it. I assume that this watch has a fixed hairspring pin. Some modern watches have an adjustable pin along with adjustable regulator. These are trivial to get in beat. I own a valjoux 726 my dad gave me on my 18th birthday (a looooong time ago). I broke the ratchet wheel with an aggressive wind 4 yrs ago. I have been waiting for my skills to progress before doing a service. I am close. Your advice is well placed and I will apply it.
