Eta 2846-2 not running
 Balance & cock assembly must be put back on the mainplate, cock screw tightened, then a close up of the coil from balance side view, is needed to check the coil for levelness.
To adjust the coil for concentricity, you apparently ought to start at the terminal bend, the terminal curve itself needs a bit of work as it should be parrarel to all other coils .
It may just need the Etachron stud and regulator adjusting, which is shown in the Youtube I posted.
I don't think that Vivat should start fiddling with the hairspring - of if he does his chance of trashing it must be very high.
What are you thinking needs repairing here vivat ?
First of all it seems that the wheel is goind to obe side, it's not flat as it should be.
Than I think that the hs is going to the right side too much
But other musters said that it could be done easier.
I'll try to do as you said tomorrow!!
Thanks to everyone!
I'll watch this video again, couldn't watch it properly at work
Ok vivat, but the balance will not stand upright with just one of its pivots in the balance cock , like in the photo you posted, it will fall to one side.  The balance has to be in watch supported by both of its pivots .
So you mean that it's okey ?
  • Sad 1
I'm not saying that the balance is ok, it has to be fully visually inspected to even approach that statement.  But i am saying that the balance wheel falling to one side while only being supported by one pivot can't be used as an indication that it has a fault. Follow joe and mike's advice, the balance has many parts and they should be checked both visually out of the watch and visually in the watch while the balance rotates.
Ahh i'm sorry, lot's of problems because I simply don't understand all the terms of watchmaking industry.
(English is not my native language)
Adjustments to hairspring  , terminal curve and regulator slot might be needed at every service time.
 Make a habbit of making these adjustments as soon as you get to bare mainplate, instal the balance cock assembly on mainplate.
See photo, notice how accessable are most parts of the oscilator thus easy to work on.
Edited by Nucejoe
  • 4 weeks later...
1 hour ago, mikepilk said:
 A problem in translation ?
Do you really mean that the pallet fork (7) is not touching the impulse jewel (2) ?
Yeah I do guess so. Because the balance now is moving perfectly ( I bought a new one) but the fork is not getting any impulse from the balance. Again may be it's because the fork and the balance are not from the exact one mechanism, but  from donors.
 You must check for presence of the roller and impulse jewel on the roller. If all this looks OK and the same as on the old balance, then  may be the zero position of the balance is totally wrong. Try to use Your own eyes and head to see and understand what happens. Put on the main plate only the lever and the balance with their bridges and investigate.
Why did You gave up from the old balance? Are the pivots OK? On the pictures, the hairspring is much out of center, but it can be easily brought as should be.
We going to need to see pictures of the balance and lever from the side vivat, close up ones. Pictures will show a lot more than you are trying to explain.
Long time no see everyone!
Nothing serious happened, but now I have a question about balance frequency. Is it all about balance ?
For example, if I have a watch with 21.600 and than I replace the balance from watch with 28.800, will it affect on the amplitude, b.e. and accuracy?
I'm asking because I did it ...
Also this balance is wobbling while running, do you have any advice to fix it?
Thanks everyone!
  • Confused 1
Thanks everyone!
Yes replace it for a balance of the correct frequency lol.  The higher frequency balance is speeding the train up by 25 %. Do you know What's causing the balance to wobble ? It might be defective pivots or the wheel might be bent, two different kinds of wobbling that look similar at first glance.
Edited by Neverenoughwatches
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
