Eta 2846-2 not running
23 minutes ago, Neverenoughwatches said:
Nah mate, it wasn't stupid at all, if you dont know you dont know and if you dont ask you might never know.
But anyways, that was kinda obvious 😉
39 minutes ago, Nucejoe said:
You need a truing caliper tool, see Bergeon 1883-04 tool.
That tool looks like an instrument of torture from the time of the Spanish Inquisition. I'll google about this tool, thanks !
1 minute ago, vivat said:
That's expensive one actually, may be you know cheaper copies of this tool?
You can pick old good quality pre owned ones for a fraction of that. Just ask to see the condition of the nibs, ideally with both truing and poising sets of nibs, the truing one have holes in the sides and concave ends to accept the conical portion of the staff pivot.
Oh gosh that's next level of watch repair art
Doesn't hurt to think next level, you already need a pair of calipers to check if the wheel is true. You could easily pick up a pair for 20 - 30 quid, I've paid much less for a pair.
Edited by Neverenoughwatches
On 11/30/2023 at 10:40 PM, nevenbekriev said:
5 min/day when amplitude is 280 degr is not sticky hairspring. Can we see good picture of the hairspring? What is the regulator position? Is the hairspring original to the balance, or replaced from another one?
Hi, as I remember the problem was in the hairspring position. It was slightly not parallel to the balance cock. That what my boss told me about it
We need to know if the regulator is set to the 'minimum' and still the watch is faster than normal. When I say regulator 'to the minimum', I don't mean the fine regulation screwis turned to the minimum, but the regulator  turned back right to the stud holder. That's why I asked for a photo.
I'll be able to make a photo tomorrow only
15 minutes ago, vivat said:
Hello everyone, do you know is there any difference between pallet fork and escapement wheel for eta 2846 (21.600) and 2824 (28.800) ?
According to the Jules Borel interchange site they're not interchangeable, in fact the 2846 pallet fork and escape wheel appear to be unique to that caliber.
  • Thanks 2
Gosh, that could be the reason for all my sufferings. Can you please share link for this site please ?
Try here.
You first select the maker, then the caliber, then the part. It will then show you all the other calibers that use that same part.
I tried it both ways, first checking the 2824 parts which turn out to be common to a lot of other calibers, but not the 2846. Then I tried the 2846 and it seems that there are no other calibers that use those parts, so I guess they are uniquie to the 2846.
16 minutes ago, vivat said:
Greetings everyone. This piece of junk is now showing me different indications in different  positions. I'm in one step to crash this mechanism. Please help 😄
If you know what can cause such problem, so please let me know
DD amplitude is a bit lower than DU, so you might want to clean the balance jewel on the mainplate.
When vertical, you are losing about 40° amplitude, which is expected, but the line is pretty flat.
So what is your problem ?
The real test is not the timegrapher, but wearing it for several days.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
