Eta 2846-2 not running
13 minutes ago, mikepilk said:
DD amplitude is a bit lower than DU, so you might want to clean the balance jewel on the mainplate.
When vertical, you are losing about 40° amplitude, which is expected, but the line is pretty flat.
So what is your problem ?
The real test is not the timegrapher, but wearing it for several days.
Yep, wearing is the best way to check them. But now i faced the problem that one lever from remontoir is getting displaced after I take stem out. So now I need to lift the dial and so on to put the stem back...  Anyways thanks !
1 hour ago, vivat said:
…But now i faced the problem that one lever from remontoir is getting displaced after I take stem out. So now I need to lift the dial and so on to put the stem back...
That‘s why with ETA movements you should only release, pull and replace the winding stem after having pulled the crown in time setting position.
Well, greetings everyone. Thanks a lot for all the help and advices. Finally I managed to finish my work on this watch. Now it has almost perfect accuracy,320 amplitude and 0.1 ms. After 1.5 years of finding parts and cracking my head on why does this watch can't work normally, I finally did it...
Here're are two pictures of polishing.
Hope you all will have even better New year's gifts than me and your beat error want be more than 0.1 ms!
Thanks again!
4 hours ago, CYCLOPS said:
the lift angle on those machines can show different rates too, your line looks clean, inbeat,  a sticky hairspring would show a lot of 'snow' for lack of a better description ....
I had a plenty of guesses about it, I don't remember when I posted those picture after or before getting the original escape wheel, fork and balance. But all in all I can say that you should never use shitty AliExpress parts (such as barrels) they are too bad to be used 😉
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
