Purchased this compound slide for my Lorch & Schmidt 8mm lathe but upon receiving it I noticed the cross slide was backwards. No big deal, just disassemble it and reassemble it the proper way. Only as I tried removing the lead screw for the cross slide, the small steel bushing/shoulder piece came off which I have come to discover, isn't supposed to happen. Now it is stuck in the brass tube the lead screw sits in and I can't figure out how to remove it as the tube closes to the same diameter as the bushing/shoulder piece from one end (I can't just punch it out).
So far I've tried penetrating oil with no success; I've tried heating up the brass tube around it hoping to break whatever potential corrosion or situation that's keeping it stuck. Maybe drilling a small hole to be able to fit a punch in and spin it around. I don't want to destroy it to take it out but will consider it if I can make or find a replacement. Any help or advice would be greatly appreciated, thank you.
(Attatched are photos of what I'm talking about and what my problem is.)
  • 5 months later...
Penetrating oil with some light smacks with a dead blow hammer? I have a problem with a rusted screw in a cross slide that I don't want to drill out and am hoping the oil and a few taps a day for a period of time will budge it at some point.
