Time setting on old mechanical watches
Cihan
Hello friends. I bought a watch from a secondhand shop. I don't care about the value of the watch. The goal is to bring it to life and for me to enjoy it.
The wooden part was in bad condition. Sanding, painting etc. better now. There were problems in the mechanical part. I handled it. Cleaning and lubrication is also ok. It's working now and the melodies are very nice. When I only listened to the working sound, the intervals between tick tocks sounded incorrect to my ears.
I used the software in the photo. What I understand from the software is that the marked area should be close to 100% or full.
Pendulum length is written as 13cm. Theoretically I should see a value of 0.723. The actual testing of these watches is done by checking whether they work within a certain period of time and how much they deviate. At least that's what I know.
I wish everyone a happy time with their watches.
first off your pallet arbor bridge is not level, so your entry and exit pallets are not going to be working as they should.
Do not get too hung up with the figures on these apps, yes i use the same as you but first i put it in beat by ear alone, making sure that the clock and the movement are level, then you set the clock in beat and you can use the app as i do as a nice warm and fuzzy to let me know that my ability to putt he clock in beat by ear alone is up to standard.
Also bring the detection threshold up more as it is listening to a lot of noise where it is positioned at the moment.
Edited by transporter
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
