Coins be hands fouling, also check the leaf spring correctly sitting on the back of the seconds pinion if it has one. This spring is there to stop the seconds hand 'stuttering'. Just need to pop the back off and look.
29 minutes ago, brunomartins said:
Hi!
After cleaning my watch, this issue appeared. When setting hours the second hand has some movement.
What may cause this? Too much tight hands?
The image shows the problem
The second hand moving backwards when setting the time backwards is quite common. I'm not sure i would call it an issue. Just tried it on my 2 year old seiko 5 and the second hand stops while i set the time. The main reason i always set the time forwards.
11 minutes ago, Nucejoe said:
 Does the oscilator stop or slow down when  seconds hands moves anti clock?
What amplitude you get  ( in wind position of the crown ) ?
Yes it slow down a little bit. Amplitude around 190
I just tried my cal 613 (same movement with date) and moving the hands doesn't have an effect on the seconds hand. I agree with @Waggy that it's probably the friction spring for the sweep seconds pinion.
Edited by mikepilk
So the next test would be to remove the hr, min and seconds hands and repeat the test you did before;
If didn't slow down the oscilator, its the hand tubes that rub.
if did , the fault is with the canon pinion and/ or minute gear, tight canon pinion ....etc.
You already have the canon pinion mounted on center arbour, so it needs not to be broached, just add a bit of oil on center arbour and turn the crown, this will reduce friction there and if you remove/ clean the oil/ grease the center arbour your done.
Stuttering seconds hand can be moved anti clock, but something must move it back, which takes us to faults said above.
Edited by Nucejoe
As the sweep seconds pinion sits inside the centre wheel, if there isn't enough tension on the friction spring, then the pinion may lose contact with the wheel driving it, then moving the hands (i.e. centre wheel) will move the seconds hand.  Does it do it if you have the face downwards?
Edited by mikepilk
 How does loss of contact between the pinion and driving wheel expalin the slowing down of the oscilator ?    which only slows when setting the hands.
Rgds
Rgds
Just to update I manage to test with hands off and could not tell difference
So the culprit is  NOT the hands tube rubbing .
I made a mistake in my previous post,
I said " its the hand"       should have said  " its not the hands "
So , CANON PINION IS TIGHT.   Being already mounted on center tube means theres a good chance broaching is not needed, presuming you have lubricated the CANON PINION-CENTER TUBE , advancing the hands like 10 times round the clock should wipe out that  excess friction, thus you should gain back considerable amplitude and  seconds hand should no longer go back either.
Rgds
I know you said you cleaned your watch, but I'm not going to make the assumption that you have serviced and properly lubricated it.
If you look at the third wheel on this Rolex 1215 (in the giff I posted) which drives the sweep second pinion (which isn't in situ), you'll find this moves quite a bit when setting the hands anti-clockwise, which in turn will always move the sweep second pinion regardless of how much tension you put on the brake spring. This is because the gear train is being moved when setting the hands anti-clockwise which strongly infers that the centre wheel is being turned via the cannon pinion and the whole gear train as well, thus a drop in amplitude and sometimes brings the movement to a complete stop. This is either the centre wheel not being lubricated properly, or/and the cannon pinion being slightly too tight on the centre wheel. Some like to have the movement come to a complete standstill as this is a type of 'hack'. I call it a 'poor man's hack'. The hand moving backward isn't such a big problem and you'll find that happens with other movements.
I'm guessing you didn't replace the mainspring, as a good amount of power/torque from the mainspring through the gear train will massively help overcome this, also, as I've already said, a well-lubricated centre wheel before the cannon pinion goes on and the correct tightness of the cannon pinion will also alleviate this. If you have a low amplitude, it suggests the mainspring needs replacing. If you haven't got at least 270 to 280 degrees amplitude, there is very little that you can do to solve this, as broaching the cannon pinion will only make the hand-setting sloppy.
That's why I initially asked about servicing and lubricating properly and this is why I bang on about changing the mainspring as standard because you are trying to diagnose and solve a problem when it was screaming at you all along. Not enough power from the mainspring!
I didn't put it quite as detailed or as eloquently as you Jon , but i did kinda say its quite common. Did anyone listen ? 🤣
Jobbers would have hard time convincing the watch owner to accept this.
👍 they're a funny breed watch collectors, very particular, very critical, very " i know there is something wrong with my watch " kind of people.  Did i just say that out loud ? 😅
A new mainspring, a strong amplitude, good service with proper lubrication, and a perfect cannon pinion tightness, then there would be no need for any explanation, as there wouldn't be any movement of the second hand in this manner.... lol
Edited by Jon
👍thats a perfect test for me then, if the second hand moves backwards when setting the hand anticlockwise then I've made a crap job of the service. Probably why most of mine do that haha.
Hi everyone ! Thanks for all valuable tips! I tried some procedures and the problem has been solved.
Basically I removed all hands, cleaned the second pinion, replaced hour and min hands to check a proper sit of them. After this I replaced the second pinion, lubricated the pivot that makes contact with the jewel. I also pulled little the spring the elevate this pinion (not sure if this was ell done).
Finally put the second hand with more accuracy and now the second hand is working properly.
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
    • Note the 8992 is 850 pounds for a liter. I think this is really for industrial settings like they say, where it would be used as a final bath in a 20,000 buck cleaning machine. I use the 8981.   That is excellent- I don't often get to see a serviced watch 5 years later, but when I do I expect to see pretty much the same oiling on the balance jewels as when it went out. I think at that area, being essentially sealed, it really should remain fairly pristine for likely 10 years. It's why some makers go to the trouble to use cap jewels on the escape wheel as well- not so much for friction reduction, but to keep the oil longer where it really counts.
