Normally I would be more confident, but this is an expensive (in terms of $ and sentimental value) vintage watch, but I am second guessing myself as I want to make sure before I mess things up that I have a enamel/ceramic dial. I have stripped the watch down which is a older Ladies Cartier Tank (ETA 2512-1) and I 'think' (95% sure) the dial is enamel. If so then I can use different cleaning techniques than I would with a normal dial.
  • Is there a way to confirm that the dial is enamel? it looks like the coating is also on the back of the dial, which is one element that leads me to think it is enamel.
  • The dial seems to have that glassy look and feel and feels cold to the touch
  • I know you can differentiate between glass/sapphire crystals and acrylic ones using your teeth.... can I use this test for an enamel dial also?
  • if it is enamel what are the chances that the numbers etc are painted on top of the ceramic, or will they be under the ceramic and safe to clean over
  • I have also read that a fizzy denture cleaner tablets can be used to clean these enamel dials (mainly clock dials) could this be an option?
Apologies for the lack of pictures, but I forgot to download the SD card from my scope last night, when I get home tonight I'll add more/better pictures to this thread.
2023-09-02-12-40-40-463.thumb.jpg.10a8f58a6ff9589821be9418eec64de9.jpg2023-09-02-12-41-05-609.thumb.jpg.a4085953e2ab0b8ca4fb6bc522f5607b.jpg
no pictures of the front and back of the dial. This means I get to guess based on your descriptions hopefully you got those correct
in order to enamel a dial or anything for that matter you have to have a counter enamel on the back side. Otherwise when the basically glass goes solid it's thermal expansion is different from the copper and it will break off. So you put basically a enamel on the backside usually not very pretty good as the same thermal properties which means the dial hopefully won't crack. It's basically a really interesting procedure if you do enameling that you have to put enamel on both sides. it also means that typically enamel dial's will be much thicker than pay for dials because enamel which is class is basically going to be thicker.
sapphire is easy as it has a cold feel. Is a very different thermal properties than the others. Glass if you gently try to scratch it without a lot of enthusiasm is relatively hard as compared to plastic which if you just touch you'll scratch.  so basically enamel dial should be like glass I suppose if you made sure it was not in a visible location or maybe on the back side take a screwdriver and gently maybe try it was some window or drinking glass first. In other words if you're a scraper painted dial it would be like the acrylic crystal it would just scrape instantly but something to its glass hard will take a little more force but if you're enthusiastic you could definitely scratch it with steel tools
normally with the American pocket watch enamel dial's I will actually run them briefly through the same ultrasonic cleaner as what they're using to clean their watch bands in cases in the front room. I don't leave it in there all day can they don't want to push my luck but promptly made enamel dial can be washed and can be an ultrasonic at least for a while. But I've heard stories of people who found out that the white is enamel but the numbers are not. The summary was talking about the numbering floating away which I haven't seen yet
21 minutes ago, Waggy said:
  • have also read that a fizzy denture cleaner tablets can be used to clean these enamel dials (mainly clock dials) could this be an option?
okay haven't read the fine print we will get the pictures of eventually okay it would help to see the backside. Then I've heard of people using the dentures stuff as I said I is wash it with the same stuff the use for cleaning the watch bands you can even take a brush to it because it's almost like washing   a eating  plate.
Off topic sorry but isn't that what we should have seen on the caseback of the cartier (fake) last week. The cheaper Vermeil versions after the Cartier branches were sold off. What is the movement inside ?
Here are the pictures I promised, apologies for the delay:
I determined that the dial was not enamel, I followed @JohnR725 advice and observed how searchable it was and this revealed it was not porcelain, so I restricted my clean to a minimal cleanup.
0175.thumb.JPG.2824641b05f44c8d025b4fe9825bbfd1.JPG0184.thumb.JPG.aa506b97486b194b3cd9b437feec33c4.JPG
This is an ETA 2512-1 movement
Everything felt right about the watch as I was servicing it, from the parts used to little touches like the black polish on the screws etc. I replaced the crystal and the mainspring as the bridal was broken off - not sure if this was done before or during servicing.
I think Mrs W will be happy this Christmas.
Watch is now finished and just have it on test before final calibration.
Photos of the final product, please.
If you had posted the picture I would've told you instantly when I look at it it's been painted.
Just for future reference of enameled dials. Typically enameled dials have a base metal of copper. If there abused dials like the images I swiped coming up first they can get broken and you will notice they broke with a dial feet were. If you look at the broken sections notice how the white enamel which is basically a ground glass has thickness versus paint which is paper thin.
You look at the lower right-hand side of the image the shiny copper and you can see the thickness of the enamel. The also see a crack that goes upwards that's another unfortunate problem of enameled tiles I get cracked. On the other hand unlike a painted dial you can usually clean that if you're careful and that will typically go away. Let's look at some other pictures online
More pictures from online. Chipped dial again you can see the copper underneath it also noticed gold objects basically fired into the enamel. As are not glued on top. Also typical on pocket watch styles the second bids is a separate thing. Enamel dials are usually several layers there's one or two white players and the gets ground in between the firing so it's nice and smooth typically I think they like to do list just one layer of one layer of white they grind it than the black stuff is applied in a variety of methods along with the gold and then that gets fired and I think when you of the gold they might do another clearcoat on top of all of not quite sure how that gets in their but it's definitely in the glass basically
I'm probably giving you more information than you need to know or care about the reason they like to minimize the firings is because each time you heat up the enamel the copper underneath can oxidize and it will bleed through which your beautiful white enamel.Then when I was considerably younger I once made an enameled bowl which did require multiple firings and there's kinda pretty but the white counter enamel of course starts to get a little bit green as the copper will eventually bleed its way through so they do try to minimize how many times after fire the dials. So and it does take a lot of effort to make these I heard or read somewhere that when they first started up they would eventually end up with huge pot kills a rejected dials until I got the techniques down
Now the backside of our dial. You can see that the white is not perfectly clean as that's only used for the front side. Often times you will see the green bleeding through this one actually looks quite decent. It also see how the second Smaller disk was in this case soldered in place. Which is a low temperature solder and some of those are lower than others so if you are cleaning N/A hot bath of water you want to be really careful I haven't had any come apart but I'm reasonably sure on one occasion that the solder had a little different look as I think it had started the melt in the boiling water so some of these alloys are very low melting.
Then since I've hijacked the discussion on enameled dials what is not an enamel dial?This is actually being currently sold on eBay as rough handled enamel dial has the casual look but look carefully the enamel has thickness like enamel but it's not and it looks like it shrunk plus it's popped off and we don't have shiny copper
Oh yes there is a clue here I already know what it is I actually have a dial like this not as bad as this something that Hamilton did now let's look at the backside we know enameled tiles have to have the counter enameling or else. So this one becomes interesting there is zero counter enameling
Not enamel But a plastic called Melamine. Replacement for enameled visits easier to do just doesn't last as well some of them last perfectly and others like this disintegrate. Or get really big cracks which cannot be cleaned. Obvious giveaways when you look at it is it looks like it shrunk and zero enamel on the backside here's a link that talks about a little more
https://blog.pocketwatchdatabase.com/2021/06/27/the-hamilton-watch-company-melamine-dial-introduction/
Continuing with the theme of dials something common with this company their name is in more than one location
Other companies have similar things some of the printing and I've seen this on enameled aisles is extremely tidy almost in a microscope to see it. Basically secret signatures on dials and sometime on watch plates.
Then I believe your movement is this
https://17jewels.info/movements/e/eta/eta-2512-1/
What?
Edited by spectre6000
8 hours ago, rehajm said:
what kind of accuracy from the ETA are you getting?
Around 6 seconds/day
4 hours ago, spectre6000 said:
What
If you tap a crystal against your teeth you can tell if its plastic or glass/sapphire. Also works on pearls.
    • Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch. Too bad 🥴
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
