So, I'm ready to try my hand at some gold plating.  I have a few old, non-valuable pocket watch cases that are base metal with gold plating (and judging from what I've done so far, QUITE a thin layer of plate).  I've taken a few passes with a cotton wheel and Dialux grey.  It certainly looks like crap now, but I'm not sure if I'm down to the base metal yet.  I'm considering Dialux yellow or orange for the cutting power to get more plate off, but I don't want to overdue it and remove the design/graving.
Just wondering if anyone has intentionally (or accidentally) taken the plating off down to to the base metal.  What did you use or how did you do it in a time-efficient manner without dulling the designs.  Pics of where I'm at so far below.  I included an untouched case and the back of the case for color comparison.IMG_1330.thumb.JPG.589f5c2976cdaaffe69e7fca9f66a170.JPGIMG_1331.thumb.JPG.1cee6e5097d63e24b5a7c4a41b1b49cd.JPGIMG_1332.thumb.JPG.9233599d5dd4d711f72e4e38e0a00a64.JPG
  • 2 months later...
I have a wristwatch case I want to reverse electroplate. The gold plating is flaking off. Under it is either rose gold or copper, and below that, I assume, nickel over the brass case.
It's a mess, so I want to remove all the gold, and replate with nickel (I thought I'd like to try gold plating until I saw the price of the solution).
Is there an easy way to remove the gold plate without a gold solution ?
I have some Nickel stripping solution - which says sulphuric acid on the bottle.
I also have "Dry acid salts" for pickling - cleaning before plating. That's sodium hydrogen-sulphate, which is pretty corrosive.
A similar question i asked a few days ago but not in relation to gold.  Ordered today sodium bisulphate salt to make up the pickle and hoping will be strong enough to strip plating and for use as a screw remover.The copper layer you are seeing might be a copper strike.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
