Radial Brushing Attempt Without A Lapping Machine
A remark: Led D1 in your schematic will have a very very short life without any current limiting resistor. Frank
thanks, mine just messed up, I wasn't paying attention and the fluid was low and I had the large basket on when it jammed into the first jar not lifting up enough, I was able to stop and save the original L&R jar but I think the shaft is twisted at the nut which is the way I obtained it, I had a machinist make me another one and it had been working for years with no problem, these are great machines...
The 10ml bottle from Cousins is a big brand - Moebius
Welcome to the forum, enjoy. Hopefully a member on this forum has serviced or repaired this particular Bulova to advise.
