Please help us to Identify this clock
Ebert
Hello all, first of all I'd like to apologize in advance in case I sound completely clueless but I'm not really knowledgeable as far as clocks goes.  A good friend of mine just inherited what seems to be an antique clock his grandfather bought while in France but he does not have much information about it and I was wondering if based on the pictures anyone could give us any information such as possible age, model and manufacturer as well as how is the best way to service it .
Any information or suggestion would be greatly appreciated.
Thank you very much 😃
Ebert
Hi Ebert,
It's likely to be a Pendule de Paris movement in a spelter case, probably latter 1850-1910. If you can post a picture of the movement (through the door on the back) - it may be possible to narrow down the date a little. I can't find a match for what remains of the name on the dial. Any competent clockmaker will be familiar with these movements.
Jules
It is French and in the style of a French Boulle. I expect it has an 8 day duration movement. The movement should have numbers stamped on the back plate one of the numbers should be the same stamped on the pendulum if so it proves the pendulum is the original one. As others have said we need to see the movement. The hands are original. All that dirt and grime will wash off on the dial.
More photos of the movement please.
Hello, Boz, Transporter and oldhippy thank you guys very much for shedding some light on it. I will post a picture I have from the back, let's see if it helps, otherwise I can I will try to take a few more once I'm home. I currently live in Singapore. Do you guys believe that could be challenging to find competent professional that could handle this kind of clocks?
It is French H & F Paris very prolific maker 1850's 1870's. It is a count wheel strike on bell, if you unscrew the bell you might find a stamp mark on the plate. It is absolutely filthy and needs a good service. These a good  quality movements and need to be handled with care. The brass and steel are high grade. The steel pivots are very hard and with out care can break as they are like glass. Any more help just ask.
Thank you so much for all the information! We now feel much more confident about it and we're already looking for a professional with experience to take a look at it. How hard do you believe it would be to replace any pieces if necessary? Again thank you so much for your help!
Hi. I would think a good clean/oil etc would get it working hopefully, parts can be found on eBay either as bits or donor movements for many French clocks. Take care as the pivots will not take any rough handling and are likely to break as Old Hippy said. Lubrication use windles oil it’s the best for clocks.
A  professional clock maker with experience will have no trouble at all in undertaking a complete service of such a movement. He will also have the means to obtain basic parts. The clock maker if he has a good equipped workshop should be able to to make parts or he will have contacts who can help him. Make sure he undertakes the basic work such as cleaning on his own premises and doesn't farm out his repairs, ask what type of guarantee  he gives and for what for, it should be at least a complete guarantee for a minimum of 12 months. One last thing have the clock in a place away from artificial heat, away from pets and young children, heat can damage the movement and the case if it were made of wood which yours is not.  Just ask if you need more help
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
