Hi all,
I need your help about this please - I have been trying to understand the variations of ETA 955.412 H0
I buy from a German supplier called beco-technic and noticed that it has been updated to ETA F05.115/F05.412 SH1 but the Hour Wheel height is 1.09mm and not 0.89mm like 955.412 H0 so they are not the same but another part is confusing me that the overall height of the new versions are lower than the old versions according to Esslinger website, how can that be possible?
Do these below stopped being produced? As I cant find any in Europe, they only have ETA F05....with hour wheel 1.09mm
955.412 H0 SC Date 3/6 (0.89mm)
956.412 H0 SC Date 3/6 (0.89mm)
Did you know quartz watches, in variation
I'm attaching the service bulletin for the watch did you notice the dates on the cover?
Upgraded means replaced. Old design replaced with new design.
I'm also attaching the one of the other tech sheets. If you go in the technical sheets somewhere in there they have the various heights the movements are manufactured with differing heights sillier ordering at the very careful specify which height you would like otherwise he'll send whatever the standard is.
612_ETA955.102,955.112,955.122,955.132,955.402,955.412,955.422,955.432.pdf ih_f05115_fde_700136_08.pdf
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
