I want to ask your opinion about this piece, whose name I don't know in English. It seems to me that the terminal part is worn or broken. Does anyone know where you can find one?
23 minutes ago, RichardHarris123 said:
Is it from a clock, since you said carriage?  It's a cylinder escape wheel and the broken part is the pivot. We would need to know the caliber to find a replacement.
Thanks,  it's from an old carriage clock, but I don't see any number that can identify the caliber. Should I measure it, in mm?
Hi it’s as said by Richard broken pivot, getting a replacement might be difficult as the escape wheels can be of different lengths, the alternatives are re pivoting the one you have or replacing the platform complete which may require you to re drill the plates to accommodate the new one.  Can you supply pictures of the clock and also the platform. Also are the balance pivots ok, if not a whole new ball game.
Haha, posting at the same time.
Some images...
35 minutes ago, RichardHarris123 said:
Post pictures of the movement, someone on here may be able help with identification.
Done!
Done!
Edited by AF10
Hi. Judging from the pictures it’s in filthy condition but nothing that can’t be rectified by cleaning etc.  the balance needs checking as the condition of the spring does not look good. These were steel springs and suffered rust spots. If a compatible cylinder platform can’t be found the alternative is a relatively modern lever escapement, they are not a cheap option.   With no markings difficult to date probably late 30s. Early 40s  . No point repivoting if the balance is no good.
You won't find a cal number on those types of clocks with a cylinder escapement. Your best bet is to find a replacement complete platform, you will need the wheel count and the length of the escape wheel, the width and length of the platform. As already been pointed out it is in a terrible condition, having an alarm is a bonus, have you got the dial and what condition is that in? Also the bell which fits under the base. I only see the alarm hand what about the minute and hour hands. How is the case is it complete with the glass panels if not they are very expensive to replace. One last thing the replacement platform look on ebay there are normally quite  few about. Make sure that the cylinder and hairspring are in good condition a worn cylinder and the clock will not work well if at all.
One of the problems in horology is the assumption of a caliber number will allow you to find spare parts. The problem is spare parts only existed if the manufacture had spare parts. Often times the manufacture was not thinking about after sales service.
In the case of a clock with a platform escapement the platform escapement was purchased typically not made by the clock manufacturer. So if the platform escapement maker was thinking about 100 years from now you might need spare parts they would've bundled up spare parts but more than likely they never did. They would prefer to sell you the entire platform.
14 hours ago, oldhippy said:
... have you got the dial and what condition is that in? Also the bell which fits under the base.
Thanks! Yes, I have... and the glass panels. Everything else is working and seems to run smoothly, but before I start the cleaning I need to find a platform that fits.
If that is so then do as I suggested in my previous reply. Just one more thing about the replacement platform try to get one so the 4 screw holes are more or less in the same place. If not that will be a dead giveaway that it is a replacement and the value will be affected a lot.
  • Similar Content
    • Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch. Too bad 🥴
    • Tool for removing or pressing the bezel? Most likely you have to remove the bezel (with a knife) before removing old crystal or inserting a new one. You can press the bezel with the crystal press if you have a suitable die with straight walls or otherwise a die that has enough clearance that it doesn't touch the crystal when pressing the bezel.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
