Many time I have run into this on older movements and that is  surface rust on the train of wheels teeth's even after pulling them from my watch cleaning machine. I end up cleaning them under my  microscope using a old oiler and whatever else. This takes time depending on how bad it is and was wondering what other do since we know this has to be cleaned.
On the brass wheels ?
40 minutes ago, wudce said:
I should has said not on the brass wheels since brass don't rust but on metal teeth's them self.
Rust residue from the pinion and leaves could spread onto the train wheels.
Perhaps a picture to show us what you mean wudce.
I guess you mean the 'leaves' on the pinion?
If the leaves have surface rust, I use some pegwood, dipped in to a mild abrasive (e.g Brasso) and rub it between the leaves.  You could push the wheel off and use a fibreglass pen.
Here what I'm talking about. It's  surface rust not the kind that's eaten into the metal, I know if it had I need to replace it. This a center wheel from a movement I'm working on and it had this on there before I put it into my cleaning machine. This can be clean off but takes some time to do so.
Yep
27 minutes ago, mikepilk said:
That should clean off with sharpened pegwood
Yep that's what I have been doing just though there was a easier way😒
  • 2 months later...
