Enfield autocorrect chime problem
Rixy
An Enfield Westminster clock I was working on (thanks for the advice on the bezel catch, OH, I got that sorted) has now developed a problem with the autocorrect function on the chimes. It was working fine and then I took the clock apart to rectify a pivot problem in the time train (it had been bent when I was putting it in) and when I had it all reassembled it chimed fine but would not self-correct if necessary.
What seems to happen is once the 3/4 chime is over, both the normal locking lever and the one for auto correct slot into place (so far so good). Moving the hand round to the o'clock, the chimes are triggered, no matter whether it is the long 'arm' or one of the three short ones lifting the flirt. I have tried adjusting the chime lock lever but too high and the chiming never stops and too low there is not enough clearance for the chimes to start. I can set it 'just right' but the autocorrect refuses to do it's thing!
I wondered if I had inadvertently twisted one of the levers but they look alright. They are a broad U shape - common feature on Enfields I think.
Have added some photos if that20231019_201850.thumb.jpg.13cab216d7b7dd4c677a70fda9d9eadc.jpg helps.
This has been driving me crazy for two days. Any suggestions?20231019_201743.thumb.jpg.4b7f6814a7c8d51bc57808155048fb6c.jpg20231019_201944.thumb.jpg.710c3d5afbada45a4f1d238dc72d3541.jpg
I'm pretty sure @oldhippywould have a suggestion for you on how to alleviate this problem
My advice is to go back to the beginning. So remove all the chime from the front, Move the hand from its center and each quarter the chime should do 1 cycle. If that is right put the cam wheel on so the next will be quarter past, if all is well do the next and the next and then the hour. Try that and then get back to me.
The good news is I went right back, reassembled it bit by bit, checked it at each stage and the autocorrect worked as it should! Not sure what was causing the problem but your advice certainly did the trick. Thanks.
The bad news is what I thought was a bent pivot due to my clumsy attempt at reassembly, was actually a bent pivot due to a worn bushing in the time train. This means that as soon as I straightened out the pivot and reassembled (very carefully) the movement, the arbor pivot for the third wheel in the time train moved and the clock stopped. It runs for a few minutes then grinds to a halt. I checked that it was in beat and that the back cock wasn't too low. The wear on the bushing isn't massive but is noticeable on close inspection.
I have attached photos so you can see the pivot in the bushing (not brilliant images). It's wearing upwards.
To rebush, will I need to prepare the hole by hand? I still have a clock from a few weeks ago requiring rebushing so perhaps now is as good a time as any to get started.
It certainly needs re-bushing you can do this by hand. The reason it is pushing up is the power on the spring pushes all the wheels up. I did all my bushing by hand but I also made bushes. I never had a bushing tool they are a waste of money.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
