I was working on the  above movement when the shock spring on the main plate accidentally came off. This is the KIF shocksprings. How do l put this back please.
Can you pls let me know the method of installing this shock spring. I am currently working on Longines L994 which has the same shock spring bu cme out accidentally. thanks.
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
