Hello from the frozen north
By RichardHarris123 · Posted
This is indeed a unique site and members including myself genuinely care about it. All we want is the site to continue. -
Hello Mark, thank you for the ad removal , like JohnR725 , I appreciate any revenue from such would be helpful. This is the one forum which encourages conversation and social interaction and in that sense it is unique All the others I frequent can be a little intimidating and answers some what terse some quite rude. I think on here we try to do justice to your site in keeping with your principals. In my opinion it is like no other. The contributors behave and act like gentlemen and ladies. And long may it continue to be so.
