 Hi Rich,  Not sure what this  type of gears bridge is called overbridge ? or what, anyway,  AS made a generation  of  movements with similar type of gears bridge. not sure if parts interchange.
Rgds
when you see enough of these movements you start to recognize the bridges and other distinct tells, this one was easy because the train wheel bridge has a cut-out for the crown wheel screw, same as the FF25, the balance cock also faces in a different direction than most, some old Brietlings used these movements.....
