Bought an old Oris off eBay which has an AS 1863 movement. The movement in the watch was shot so picked up a very good condition replacement movement.
Prior to service it was running at -16 secs with a beat error of 0.4, so acceptable.
Serviced the watch and after service it was still running slightly slow (-10), beat error around .4 but with better amplitude.
I put the dial and hands on and let the watch sit for around 15 hours. In that time the watch gained around 50 minutes. Back on the timegrapher but with the same result.
I demagnetised the watch again, centred the rate adjustment and the timegrapher shows -220 secs per day, beat error and amp the same as before.
The watch is still running at around 4 minutes per hour fast.
Confused. What does the timegrapher actually measure off? Could the balance be catching but if so should that not reflect in the timing?
Put the watch on the timegrapher, adjust the rate as possible closer to 0 s/day, do not change the position and observe the second hand. Is it making one revoluton exactly per minute, acording to another trusted timer/watch?
Edited by nevenbekriev
Thanks for the replies.
It's running the same both face up and face down on the timegrapher. I left it running face up but placed it face down about 90 minutes ago and it's already gained 4 minutes.
I'll try the adjustment to zero and time it with a stop watch.
The balance is the one that came with the movement, although that may not be the correct balance. Assumption is always dangerous! I have a balance from an AS 1717 so will give that a try.
EDIT - Tried the timing test with the existing balance and one revolution of the second hand is taking 56 seconds. Time to try the other balance.
Edited by SpringMangler
  AS 1717 is 18000 beater and AS 1863 beats 21600 bph , so if you have a 1717 in a 21600 movement , it will run slow.
Otherwise its a serious hairspring issue or loose canon pinion and the like.
Rgds
Edited by Nucejoe
Rgds
Ah, sorry I misunderstood. I though you meant they were interchangeable.
What frequency is your timing machine saying you are running at?
I believe the balance are interchangeable, in the sense they will tick in either movement. But if you have a 21,600 balance in a watch that needs 18,000, you are getting an extra tick each second. 12 seconds extra per minute. You observed the minute hand making a turn in 56 seconds, so the math doesn't seem to work-except, often the higher beat watch will have 20 or so teeth in the escape wheel, and the other gearing has changed.
On that note, for a "family" of calibers, often the center distances didn't change even though there were gearing changes to allow raising the frequency. In some cases the gearing can get mixed up- so maybe you have a 4th wheel meant for an 18,000 beat watch but a 21,600 balance, or something similar; it can get a bit complicated.
Edited by nickelsilver
It is showing as 21,600 so the balance appears correct.
However, I think you may have hit the nail on the head with the gearing. I've swapped the 4th wheel out for the one off the old movement. Initial timing of the seconds hand appears to give a 60 sec revolution but I'll let it run for a few hours to see how it goes.
Many thanks for the help and saving what bit of hair I've got left.
Haha, Do you remember the emoticon wrt forum use to have of the guy plucking out his own hair , I miss the guy.
Balances are interchangable , balance completes are not. Gears of the train too are for different beats.
We should have a thread on Dr ranfft's site, tons of info is packed in it.
Rgds
Edited by Nucejoe
It was clear from the beginning that the balance is not ‘wrong’ and it is something about the ratio of the train.
When just the balance is the ‘wrong’ one, then the movement will gain or loose more than 4 hours /day:
21600/18000=1.2
24x1.2=28.8       28.8-24=4.8h/day
24/1.2=20           24-20=4h/day
Now, that You had changed the 4th wheel, we have correct ratio to the second hand. Hopefully all will be OK, but still the ratio to the 5th wheel has to be checked.
Changing the wheels between one family of calibers with different BPH not only leads to wrong train ratio, but to incorrect gearing, as the wheels have different modules or diameters. That’s why, the wheels must go together as a set and not to be changed between sets with different BPH. But, as You see, sometimes the movements work without stoppings, even with wheels from different sets, despite the wrong gearing.
Mechanical watches can be quite interesting at times. The timing machine is listening to the sounds of the escapement controlled by the oscillation of the balance wheel. The timing machine does not care about the hands or anything else it only cares about picking up the sound of the ticking watch. So you can have a absolutely perfect timekeeping on the timing machine watch that can have other issues as you've now discovered.
So balance wheel oscillates at a frequency. The gear train of the watch is to reduce the frequency down so that the hands revolve at the correct rate.
When I was a young student in school working on an Omega watch I had your exact same problem. We ordered a replacement wheel and the watch did not keep time.
This comes up for unsuspecting Rolex collectors the exact same thing.
Your ending up with the same problem here is a series of watches that were made in differing frequencies. Where the base caliber is 18,000 and later versions basically identical watches came in other frequencies. So the difference would be the balance wheel but oscillates at its correct frequency and just a couple of the gears in the gear train that a change the ratio. So eager to assemble the Rolex for instance will mix-and-match and then you have a serious problem.
So timing machine can be very happy with the rate of oscillation of the balance wheel. But you do have to have the right gear train ratio to go with your oscillation timing machine cannot measure that.
I suspect if you take out the offending wheel and compare it with the gear that should be in there and look at the number of teeth on the gear and/or pinion You will observe that they do not have the same number of teeth.
Glad I found this. I have an absolutely cursed Lorsa P72a (Ranfft lists as 21600, no mention of 18000) that has been a "learning machine" for me. Everything that could go wrong has gone wrong; I got a balance complete delivered from Italy, pallet fork horns were bent, host of other problem all solved until it ran perfectly on time at 280deg, 21600. Then last night I put the seconds hand on it and it makes a perfect 50 second revolution.
I have a donor I didn't use for anything and will start by checking the 4th wheel teeth count in hopes that one is 18000. It's very clear I put in a 21600 balance complete.
21600÷18000=1.2   60sec÷50sec =1.2   sound like the train is for an 18000 balance.
P72 runs at 18000
P72 runs at 18000
I see that now in Ranfft's archives. The other difference illustrated there was that P72a has a mobile stud carrier while P72 is fixed. Mine had a mobile carrier to begin with so I assumed P72a (even though it says P72 under the balance). Same mobile stud carrier on the other parts movement I had on hand (a P75 with calendar). I did not notice the difference in beat there before.
So I bought the wrong balance, and while I was certain I remembered the ebay listing saying P62/62A, P72/72A I now look back and it definitely says just P62A/P72A. What a mess. I was so happy to see this watch tick after all the issues I overcame, and now I need to decide if the existing sunk cost is worth another $30 and a month wait for the right balance. Boo.
Additionally, there are variants for MT Antichoc (which is what I need) and Incabloc. The former seems harder to come by.
(Edited - correcting the listing as P62A/P72A)
Edited by mbwatch
So I bought the wrong balance, and while I was certain I remembered the ebay listing saying P62/62A, P72/72A I now look back and it definitely says just P62/P72. What a mess. I was so happy to see this watch tick after all the issues I overcame, and now I need to decide if the existing sunk cost is worth another $30 and a month wait for the right balance. Boo.
I'm a bit confused by your last statement. If the listing now says p62/p72 that would be the 18k bph, but you have a 21.6k balance.
I think i would go with that the movement is p72 that runs at 18k. Your timegrapher has already indicated that the new balance is vibrated to 21.6k . Since the hands are moving at 1.2x , the train must be geared to run correctly at 18k . Can you varify it with a tooth count of the gears.
Hastily typed, and missing the "A". The listing was P62A/P72A. Apologies for the confusion.
Ah ok, so it seems the balance is incorrect and too fast.  Out of curiosity if you set your timegrapher manually to 18000 what time rate would you get ? Surely out of the tg range as it would be 240 minutes fast.
The carrier might have just have been a modification if it fits both calibers. Either fitted in the factory as an alternative to the fixed stud, or maybe the balance complete was changed afterwards by a repairman, maybe all that was available at the time.
I'll test this later. I'm am pretty confident if it can read it, it will be bang on 240 min fast. The movement is running perfectly +2s, 0.0, 280deg, albeit in an alternate world where one minute is only 50 seconds long. I use the open source tg timing software rather than a Weishi, and it is pretty flexible in what it's willing to calculate and display.
I did count the teeth on my spare P72 escape & 4th wheels. They're 15 & 60 respectively, same as on my too fast movement. So I won't be swapping in train parts I happen to have on hand. It will need to be a different balance if I do pursue this.
Thats a bugger, its certainly not something you can adjust with the quicker balance. I'm not sure of complication of changing the gearing, might be just a 72 tooth fourth wheel but could be all of needs changing.
There are a lot of 72A junk movements available, mostly without a balance, even in my own country. So replacing the whole train at not too much more cost is feasible. I wouldn't take a chance on ordering a 4th wheel alone, in case it's mislabeled. After that I would have a nicely hot rodded old Waltham with a perfect dial and higher bps.
this appeared to be a hard movement to track down but I had a suspicion of something and found the verification here
now with the proper name that I can look up we find something interesting? This is a problem that comes up commonly with Rolex for instance where and I haven't even looked at the parts I just snipped out the listing were often times things refer back to the base caliber without the letter a perhaps the case of Rolex a lot of the movements will go back to the base caliber run it 18,000 but the other ones are running at higher frequency and of course people start mixing and matching and not look at the exact parts and then you get stuff like this balance wheel one frequency watch another or worse yet mixing components the gear train is now at some bizarre frequency
so for my listing above it looks like that letter a is really important if you what your balance to oscillate at the correct frequency. Then 72 isn't even the base caliber it looks like the 62 is the base caliber. A case for balance wheel cross references like this
Mbwatch didnt say why the balance that came in the watch needed changing. Seeing as there are a lot more variations for movements that run at 21600bph that one was probably incorrectly fitted at some point.
I think he was hinting without saying
the first part of what I quoted above the says about everything went wrong and he got a balance complete from Italy. This means that an accident probably occurred.
I know it's a silly question but are you sure that it is a P72 a? Because if that's what you have it's supposed to be running at 21,000.
there is a number again but where's the letter a? This as you're finding out what happens when you start mixing and matching and their variations of the watch frequency the balance wheel oscillate at its natural frequency and the gear train will revolve at its gear ratio and have somebody's been mixing and matching then things get really interesting as you've discovered.
Further up back in post mb tells us that it was an assumption based on the balance that it came with. P72 was found under the balance.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
