Advice and direction please. Time set working. No hands moving
Advice and direction please. Time set working. No hands moving.
I have a lovely watch. Bulova Caravelle with AS1712/13 movement. I have cleaned the movement and assembled, using internet assistance, followed exactly. I have done this 3 times now. Everything runs correctly, timegrapher allows good figures. Dial side is completed and the dial fitted and hands installed. Turning time set for midnight and fitting hour hand, rotate for clearance and fit minute hand at 12. Rotate and check calendar day date functions. Both are correct.  Push in the stem.
Here's my problem. The hour and minute hands do not move! Everything appears to be working. Balance rotating. None of the hands move from the midnight under normal time conditions. Pull out the stem. Time set works.
Advice as to what I am doing incorrectly would be greatly appreciated.
Beginning the total disassembly aging. Next stop clean, then.. I'll keep you posted.
Good this hobby innit?
Regards
Ross
Edited by rossjackson01
More information
Is the seconds hand still running correctly?  If so, it sounds like you probably have an issue with the cannon pinion.  On that AS movement is it driven by a pinion on the 'drive wheel' that connects to the minute wheel, then on to the cannon pinion rather than being friction fit on a center wheel?  Could be a loose pinion on that driving wheel not allowing enough friction to drive the cannon pinion?  I would think it would have to be somewhere between the cannon pinion / minute wheel / driving wheel pinion gear train.
Edited by thor447
Thank you Thor447. As I remove the chain of wheel I'll do a check. I've change the cannon pinion with the replacement from the donor. No click' on the original , but a good sound form the donor. Still had the problem. Probably as you suggested. Going shopping with my bride now. Will resume later in the day.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
