Hello everyone, I'm in need of setting lever for Pobeda 15 jewels 1950-60 movement. Picture is from web as mine is undergoing autopsy. Lever does not have to be from central second complication I believe.
under the 15 jewels there is a diamond shaped stamp exactly as on title photo M143 where number 4 is underneath 1 ,so it could also be 134. Pobeda and Zim are very much the same movements from what I read.
That is the mark for the First Moscow Watch Factory used between 1945 and 1963.
According to Ranfft production was shared between 1st Moscow watch factory and the Watch Factory Maslenikov for a while.
Check out the link here. It suggests that there are variants from Pobjeda, Raketa, Slava, Wostok, and ZIM. I would be surprised if you can find a new part for it which means that you will need to look out for a donor movement. Looks like there should be plenty of choice.
Yes, plenty of donors on ebay but all of them with push pin. Mine is pre 1957 with screw fixing the lever
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
