Hello.
I'm trying to measure an automatic watch with a timing machine, but for some brands such as Lange Sohne, Breguet, Panerai, etc., the lift angle doesn't appear on watchguys site.
Is there a site where I can see it? If so, please ask for help.
With a few exceptions, most watches use movements inside which are made by someone else, for example I am currently working on an older Accurist watch, which has a movement inside made by ETA. You should take the back off the watch and look for a makers stamp on the movement, this is quite often located under the balance wheel (see example below), usually a little shield with some letters inside to identify the manufacturer and then some numbers/letters under this for the model number (Cal.). You may have better luck looking up the movement than the watch manufacturer.
Post some pictures and I'm sure someone here can identify it if you are having problems 🙂
Edited by Waggy
