Hello all
I'm new to watch repair, but have the basic kit from my father.
Just wondering what would be a good movement to start on? I was thinking of buying a SW-200 or ETA no date and just start from there (please don't say pocket watch lol).
Are there instruction manuals a bit like putting together a Lego model? Or are such guides not available. I really worry about using the wrong screws.
Best Wishes
Richard
Hello and welcome.  Pocket watches are recommended because of their size but if that's not for you then both your suggestions are good movements.  I far as I know there aren't instructions as you described but exploded diagrams. Such as this snippet from the SW 200.
4 hours ago, ShambaBasher said:
Hello all
Best Wishes
Richard
What's wrong with starting on a pocket watch?  However, I would clarify that recommendation to be one that is a modern movement (vintage wrist watches or pocket watches can come with too many gremlins).  Something easy to find parts, in case you lose or damage one, and one that you can find videos on assembly/disassembly.  I started with a SeaGull ST3600 (ETA 6497 clone) and turned it into a pocket watch, but you can also turn them into a large wrist watch.  I learned lots from servicing that movement.
Edited by gpraceman
Hi and welcome to the forum.   There are service sheets available but none on the Chinese, and Swatch Group products which covers quite a few watches. The thing to do is if you need one just ask, someone will have somthing .
At one time Swatch group did have something which was step-by-step walk-through of several watches. Unfortunately as it involves moving graphics they made use of flash which is been phased out. But otherwise was a step-by-step of disassembling and reassembling four different movements. For instance this is a sample of one page of a pocket watch.
Swatch group is interesting in that some stuff is available at least some of the modern ETA quartz and mechanical technical sheets. Vintage technical is interesting because often it was only scanned for parts availability and often times will be missing servicing information if it even existed at all. Watch companies have the silly notion that anyone working on their watch should know what they're doing so a lot of times service information was not available.
SW-200 or ETA
I have the links below are you can find some technical information for the watches you seek.
https://sellita.ch/index.php/en/movements
https://shopb2b.eta.ch/en/
