Progress to date on homemade watch parts, The movement is an Avia I bought off ebay for a few pounds. I will buy the glass and strap in the future (hopefully if things get that far).The plan is the rest of the parts will be DIY
Case fabricated in 3 parts
Raw material for case
post-143-0-96137300-1441055465_thumb.jpg).
  • Like 6
A bit more progress. Just the crown to make, put on some dial markings, and a clean up and tidy.
Hands made out of a broken main spring. Hour wheel extended
Fourth wheel ground down to remove sub seconds
Crown will be made out of an old brass bolt and fitted to an extended stem
Dial markings to be added
Watch is keeping good time
  • Like 5
Outstanding work Michael,
Truly impressed that you made those hands yourself but please tell, how did you manage to cut the spring steel to that accuracy, was it some sort of die or was it by hand.
Looking forward to the next installment.
Cheers,
Vic
Hi Geo, I had not thought of changing from the raw brass and just buffing when needed. However, your post has got me thinking. If I do anything I think it would be gold plated, unless you have any other suggestions?
Hi Vic, they were done by hand, and I am not entirely happy with them, but time restraints means I need to press on. The method I used was actually quite easy, and it was as follows;
Cut an over lengthed piece of main spring and bend reasonably flat
Soft solder at the ends to a thin piece of oversized brass. I used 0.5mm as it is what I had for the dial base
Drill the hole where it fits onto the hour wheel
Then use a dremmel type tool with grinding disc to shape your hand to how you want it. The brass helps to grip it, and also to control the grinding.
During the grinding the hand will naturally come away from the brass. Grind off to finally release the hand from brass sheet.,
Tidy up as required with dremmel type tool and then sand on a piece of wet and dry, both sides.
I put the hands on a 2mm piece of brass sheet and heated from underneath. As soon as hands start to turn light blue take the heat away
Thanks for the info Michael,
Most ingenious and quite frankly they look ok to me, I wondered how you got them so thin.
Cheers,
Vic
  • 4 weeks later...
