After accepting the fact I am a messy worker I need to find a better way to store watch parts (all parts) while I am working on them and also while I am storing them, for example when waiting for parts etc.
Currently I use the normal bell type parts/dust trays, and have also tried the yellow type from CousinsUK as seen being used by Mike on My Retro Watches. Each is good, but not a complete solution. I still have a dial holder floating around, and a balance tack with a balance on (depending where I am in the re-build process) there is also a bracelet kicking around in various stages of re-build and movement rings, cases, case backs, old/new crystal(s). If I have to store these it can be problematic and parts can easily become misplaced or orphaned, and the tops cant be secured so if you knock it over you are hooped. One of my other major gripes is also that the bottoms are flat on the parts trays, meaning that you have to chase the ratchet wheel and other flat parts around trying to pick it up with your tweesers, and maybe scratching them up in the process.
So I have decided to design a parts tray (system) that fixes all of the above!
Here is a sketch
Lid: self explanatory, except it will have a course thread on it so that you can screw it down for long term storage
1) Dial and (temporary) balance and mainiplate storage
2) compartment about 10 mm high to store the mainspring
3) Parts tray, 6 compartments each divided into 2 (inner ring) to make a total of 12 compartments, each will have a furrow which will allow the tip of the tweezers under a flat component, and also somewhere for the screws and wire springs etc.  to be when you try and pick them up
4) large open compartment for bracelet, case, caseback etc.....
I'm anticipating that each compartment will screw into the next but also be freestanding, the design will be modular, so you can change the order they screw together or if you don't need compartment x then you don't have to include it in the stack.
Thoughts, ideas?
Actually, this guy beat me to it.... (LINK) so may just tweak the design a little:
Edited by Waggy
Typos
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
