10 minutes ago, LittleWatchShop said:
How the hell do I install it???
I use an eyebrow tweezer to do it. It grips the spring so securely that you can muscle the ends in.
From which side do you enter?  Does it matter?  Do you orient it orthogonal to the plate, or in the plane of the plate?
First,  DO NOT ATTEMPT INSTALLING WITH CHATON AND END STONE IN  THE HOUSING.
All above must be taken out before you attempt.
Second all you need is to examine the image here,
https://calibercorner.com/kif/
The two short legs just slide in with ease, no need to force/ twist/ bend or anything of the like, JUST SLIDE THE SHORT LEGS IN.
Good you asked, most anyone breaks first asks later.
Edited by Nucejoe
Yes, certainly...cage with chaton is removed.  I will lay the spring flat and scoot it in as I show below.
8 minutes ago, nickelsilver said:
Hector's got it. There's no trick, just excellent tweezers and care.
Excellent tweezers may be the challenge for me.  I have tons of tweezers including some crappy eyebrow tweezers.  Maybe I need to modify one of my dumont vintage tweezers (eeek!!).  I will ponder.
No need for tweezers. I would try by holding it down flat with some Rodico on the back of the long legs. That way it's not flying off anywhere. Then push the cross piece with some sharpened pegwood.
Here is how I installed one of mine. I actually found that I needed to have the jewel in the chaton or else the spring wouldn't stay level and I couldn't get it in. I use the plastic to position it and then an oiler with the force applied the long axis to snap it into place. You can see that when I first tried to apply force with the oiler perpendicular to the direction the spring needed to move, the oiler would flex. Once I came at the spring along the direction of force it snapped right in.
Edited by GuyMontag
  • Like 7
  • Thanks 2
4 hours ago, Nucejoe said:
OK, for some reason that previous post messed up.
I have done it.  I used tweezers AND rodico so that the spring stayed with me.
Not much force was applied to get the spring in.
Now that I am done and have seen Guy's solution, I wish I had waited for his post, because that looks like a brilliant method.
Whew!!  What a pain.
Edited by LittleWatchShop
A lot of it depends upon a variety of factors. In other words some may go in without disassembly and others you may have to disassemble. I don't think I've ever have even done a Kif before. I know with  incabloc Some of those it works better if you just push the entire setting out and it goes again effortlessly if you try to get it in with the setting in place it's a problem at so these are just the push the thing out and put it down and put it back together again.
Just wanted to thank you for this post!
I used the plastic sheet approach plenty of times since I saw your video. Primarily for shock springs, but also for the rotor clip on a Rolex 2035. It makes a huge difference. Really a game-changer for these kinds of fiddly tasks.
I'm glad it worked for you too 👍
  • 6 months later...
If I can revive an old thread, I found this incredibly helpful. Some suggestions were more useful to me than others. I lost one spring and broke another before I successfully got the replacement in place. The biggest thing I would say to any novice at this is to remember how easily the thing accidentally slipped out. It goes in with equally little force. Be gentle and patient.
Things I found helpful:
  • I used a pair of tweezers in one hand and a large oiler in the other. I mostly used the tweezers closed to steer it into place, so I might have been able to do it with two oilers.
  • I surrounded the setting with a small circle of Rodico. This helped for the time the spring magically vanished from under my tweezers and oiler as instead of entering orbit never to be seen again, there it was at the edge of the Rodico boundary.
  • I tried with the jewel in place but the spring sat too high and would not slide in. When I removed the cap jewel and chaton it slid in first try. That's a lie; it was more like the sixth or seventh try (did I mention being patient?), but it did slide in whereas with the jewel in place it would appear to be lined up perfectly but still refuse to go in.
I found that using the plastic sheet made it too hard for me to see when it was lined up perfectly, and also it meant that the spring would move if I took my tools away, so I ended up living dangerously and doing it uncovered. I think one time when I was using the plastic sheet I actually had it in place, then a slight movement of the plastic slid it out again. It helped that I had some spares on hand if one did fly away, but either I'm getting a bit better or I was lucky today. (I have to say, though, that I have found the plastic sheet approach incredibly helpful for other tasks involving springy parts.)
Did I mention being gentle? The time I broke a spring (see image) came from trying to 'snap' it into place as described by Guy above. For me there was no 'snap' when I was finally successful; it slid in with near-zero force, and I'd say that if your oiler is flexing then you're not lined up yet.
  • 9 months later...
As a result of this thread, I was able to successfully reinstall the KIF UltraFlex shock spring. As stated above, patience and a piece of Rodico are your friends.
Thanks again.
Edited by TKM3RD
add'l info
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
