Hello everybody,
I'm starting to learn to service 60's/70's Seiko, thanks to all WRT members I've found a lot of valuable information here.
30 minutes ago, nico said:
Hello everybody,
Welcome. Seiko's are excellent for us beginners. Mike's Youtube 'My Retro Watches' is a great source.
He's one of my favorite ones 👍
For now I'm working on a 2202, taking a lot of pictures and annotating them, step by step, day by day, getting tools when needed... Learning and practicing in other ways while waiting to be ready to continue on this one...
Hello and welcome to the forum and greetings from Geneva (you must be somewhere close).
Taking good pictures of EVERY step and every screw has been my recipe as well.
For the particular picture below, don't forget to note that the screws with three grooves are reverse-threaded (you screw them in/out the opposite way to normal).
Cheers,
C
16 hours ago, nico said:
Hello Knebo !
You're right we're close ! Good advice, an improvement will be to automate the process of documenting all my steps. Maybe investing in a cheap USB microscope/webcam (working with linux) could help a bit.
  • 2 months later...
Update, few weeks after...
There's a lot I could say, so I'll try to focus on actions and results.
My first service, on a simple but small movement, was given for junk from the start:
A Seko 2220-3470 "socie"
No hope?
After a truly artisanal cleaning:
But in the end, while trying to polish the pinion, the wheel came off its balance shaft. No hope 😕
Anyway, I reassembled and lubricated the rest of the parts (with NOVOSTAR 17313 Type B for everything, and Moebius 8300 grease) (I'll probably make a separate post for all the equipment and techniques I use, in the right topic). After that I opened the main spring barrel (thanks to WRT I found hints here, thanks to my luck at the end I retrieved very shortly all the pieces 1 meter away).
I also started to polish/renovate some cases and acrylic glasses, and started to implement a diary system (python/mkdocs).
During the Christmas holidays I brought back to life a Lord Matic, but that's another story 😉
Edited by nico
  • 8 months later...
On 11/3/2024 at 8:58 PM, Knebo said:
I was there too!
I met Philippe Dufour there 🤩
@nickvon found out about another event in Geneva next weekend. Maybe another opportunity to meet.
It could be great to meet us altogether ! What is this event ?
Is it a topic relative to the events ?
Edited by nico
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
