8 minutes ago, RichardHarris123 said:
I haven't tried it, even though I  have worked with chemicals and in a lab,  wouldn't want to try this at home.
https://www.china-machining.com/blog/how-to-remove-chrome-plating/
Thanks Rich, interesting read . From reading about chrome plating in the past it is a more hazardous process than nickel plating, more toxic chemicals are used. Nickle plating is fairly straightforward and reasonably safe when using precautions.
