Help with chimes on an Elliott clock
Rixy
I have cleaned an Elliot dual chime bracket clock for a friend (it was dripping with oil) and have managed to reassemble it. The platform escapement is working and I have adjusted the strike and that seems to work but the chimes are baffling me! There are a couple of extra parts (a sort of star wheel and cam and an extra L lever) that I am unfamiliar with (have worked on Garrards, Smiths and Hallers and never seen them). I suppose everything needs to be aligned but I'm not sure how. If anyone has ever worked on one of these and can give some advice, I'd be grateful.
Have attached photos of the chime mechanism.20231210_212526.thumb.jpg.323e24da88c97977c3d8fd29b6fefb7f.jpg20231210_212526.thumb.jpg.323e24da88c97977c3d8fd29b6fefb7f.jpg20231210_212526.thumb.jpg.323e24da88c97977c3d8fd29b6fefb7f.jpg20231210_212526.thumb.jpg.323e24da88c97977c3d8fd29b6fefb7f.jpg
Hi the extra pieces are for the night silent mechanism, it needs to shut off at 11pm and come back on at 7.15am. When your L shape lever is on top of the cam that will shut off the chimes, however i find it easier to set it for the 7.15am when lever is just coming off of the cam. Hhope this helps.
Thanks Stuart2, I was beginning to think along those lines. I realise as well that I had the silence lever in the wrong position. Have also found that the chime cam has to be just right on its arbor (not too far in or out) to prevent catching on other levers.  Have made some progress and will persevere!
Stuart2 has hit the nail on the head. I have two of them myself they are extremely well made movements. Some are also fitted with a silent running platforms. I myself collect  Elliot clocks I have five other time pieces all different types of cases.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
