A have bunch brass brush what a want to know is how do you use the long brass bush as shown on the picture uploaded how do you cut it to size ?
Edited by Murks
Hi Murks,  brass bushes are used when the pivot hole has become too worn and allows the wheels to jam up. At this point the hole is reamed accurate and a bush inserted and a new bearing hole for the pivot is reamed in the new bush.  Cutting them on a Lathe is the usual method, they can be cut with a saw and filed down then finished on fine grit paper. It’s tedious job by hand but if you have no lathe it’s the only other way.
