Balance Wheel Wobble!
Len33
Hello, everyone!
I have a pocket watch balance wheel that has a slight wobble on it when it is spun. (Collet and hair spring removed) Can you suggest a way of correcting this wobble without causing damage to the pinion? It obviously needs to be 'manhandled,' but how?
Thanks.
Hi Len,
Five possibilities.
1. Broken jewel...since you've removed the hairspring I assume you would have eliminated this.
2. Too much endshake..ditto above..
3. Bent pivot.... inspect pivots closely. If bent then you need to change the balance shaft. While some guys have success with bending pivots back into shape your chances of failure are high.
4. Balance wheel not level on staff. You need to remove the roller table, user a stake larger than the riveted portion to get the balance wheel level, then re-stake the balance wheel so that it stays put. You also need to re-poise the wheel as it is possible the wheel has shifted from its original position relative to the staff.
5. Balance wheel arm bent... not common but possible.. again roller table comes off,  Balance on staking block, gently massage the arms of the balance wheel to get it back in shape. Make small changes and check constantly.
Watch truing calipers can help identify the problem but don't attempt to fix the wobble with these as it will just break the pivot.
Sorry there is no quick fix!
Anilv
If you haven't got bent pivots or cracked/chipped jewel then the balance wheel is bent, not good for isochronism. I personally true balance in calipers and would suggest this is the best place to do it.
There are two Truing processes, one in the flat and one in the round , always start in the flat first. Start at the balance arms always flat these first and then when the balance is true at the arms work your way round until the balance is flat. Small amounts of pressure can alter the flat quite easily, so no hammers involved!.
Truing calipers are made for this purpose, the balance staff does not sit on the smallest pinion but sits on the first shoulder of the pinion. On good quality Truing calipers a hole is seen a short distance from the end of the bush, with a good loupe you can actually see into the hole and see if the pinion ends are straight themselves when the balance is turned in the calipers, just make sure the calipers are fairly tight up to the staff shoulders before attempting truing, you don't want to break the pinion so.
There is an adjustable Truing gauge attached to all good Truing calipers, it's there for a purpose. You will notice a small vee in the Truing gauge, this allows you to miss any adjustment screws that may be in the way of the gauge when rotating the balance.,
Truing in the round is a different matter but still done in the Truing calipers. Best tool for this is a small flat notched lever bar. This sits over the rim of the wheel and is used to bend the rim inwards or outwards. It's specifically thin to get into the gaps between the adjustment screws. Always true from the top of the balance wheel, not the bottom.
It takes time and can be frustrating, but with practice it's doable. Don't forget to check poise afterwards!.
  • Similar Content
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
