Omega cal 1012 not holding power
Hi All, I hope someone can help me with this issue which is driving me nuts. The watch has been cleaned and serviced as it was not working at all, the centre wheel was damaged and has been replaced and when all work was completed the watch runs well  with good amplitude 260 to 280 on the timegrapher. the issue is this, the watch will wind manually and if you manually push the rotor around you can clearly see it winds the ratchett wheel in fact from zero power in the spring just using the rotor the watch will start working, but after about 2 days on the auto winder from a full manual wind the watch stops and the fault seems to be there is no power in the spring so although the auto wind appears to be working it does not if you see what I mean. I even fitted a brand new spring 3 days ago just in case but still the same result. I have enclosed some pictures in the hope someone can say you have done this or that wrong, any help or advice appreciated. thanks in advance Tony.
You say that the automatic winder functions as long as you move it manually. That means everything should be assembled correctly.
Faults that come into mind:
- to much drag in the automatic gear train (does the rotor swing freely when the power is let down?)
- worn rotor pivot (to much play?)
- rotor touches the plate or the closed case back (any marks?)
Edited by Kalanag
Adding to what @Kalanag says.
Holding the movement vertically and slowing rotating it, does the rotor move freely?
I have a couple of 1012s, and the rotor spins very easily.
To check auto wind watches, I let the mainspring down, then (if you don't have auto winder machine) I wear them for a couple of hours. That should give nearly a full wind.
thanks for the replies, the rotor spins really freely there is definitely no dragging or witness marks to indicate otherwise. I am going out in a minute I will wear it and see what happens. I am thinking oldhippy might be right as it winds manually ok. If it does not kick into life I will replace the auto works. Thanks again I really appreciate the help.
The problem that usually happens to this auto module is wear of the reverse wheel. To check it, wind the spring to the end manually and then turn the rotor by hand to see if the auto is winding. Try in both directions and see vhat is the minimal angle of the rotor movement left-righr that brings rotation of the auto. Should be less than 90 degr. But, in case that the watch stops and no power on the autowinder, then check if the rotor is not pressed by the back. Shaking the watch must rotate the rotor and this can be filled and heart by the vibrations of it. You can put the watch on autowinder with no back, to see what happens.
Edited by nevenbekriev
current update on this issue, I went out wearing the watch and it started working so I put it back on the auto winder and it stopped after 8 hours, I checked the mainspring and no power it was completely let down. I took the auto works apart cleaned it again put it back together still same issue. I purchased a used auto mechanism complete unit which came today, I have fitted it and the difference I noticed straight away was that my rotor had some resistance as it went round where as the old one when the rotor was on it whizzed round with the slightest touch really fast. fingers crossed this was the issue. I will let you know.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
