Anyone got experience of the JLC 240?
Scootle
Hi all,
I have been asked to have a look at a JLC 240/3 movement that stops randomly every 4 hours or so. I've cleaned it and the heavy duty wheels under the main bridge are running freely. The third wheel (#210) is held between the base plate and the mezannine style bridge that forms the lower jewels of the balance and pallet fork so rather conveniently I can see immediately that it is this 3rd wheel that is causing the problem. It is touching the beefier intermediate wheel (#203) to the right of it in the picture. The problem is that I can't see that either part is damaged.
Does anyone know if this is a known fault? I did consider that the 3rd wheel could be a replacement part but the parts list suggests not. Both parts are true and not bent. Neither show sign of wear. There's no end shake on the 3rd wheel and only a small amount on the intermediate wheel but that would tend to make the touching worse not better. ( in other words, in the picture, the intermediate wheel will move very slightly to the left tending to push harder on the 3rd wheel as opposed to creating the required gap). The jewel that the 3rd wheel is sat in is absolutely flush with the base plate so I doubt I will be able to lift the 3rd wheel enough by moving it.
I am at a loss - any help or advice would be gratefully received.
Scott
36 minutes ago, nickelsilver said:
Some more pics would help, are you sure you have the 3rd wheel (and everything else) the right way up? Sometimes you can actually put wheels in upside down and they almost work.
thx for the quick reply. I can be sure they are the same way up as they were when I disassemble it but since it was showing this problem before I got hold of it I will double check the orientation. However, the long pinion on the 3rd wheel would prevent it from being upside down. The intermediate wheel pinion engages with the mainspring barrel so that is definitely correct. I have lots of photos. I always photograph while disassembling. Which would you like? In this one you can see the intermediate wheel and about a quarter of the 3rd wheel resting on it.
Going by your photo. Looks like something has been rubbing the barrel cap. The teeth on this type of barrel are pron to be rough and poorly finished check them all. Teeth on that wheel also look rough so need checking. What about the pivots, have you burnished them if not do so. Are you sure all the wheel holes are good no rough marks in side. Springs are very powerful in this movement as its an 8 day duration. It must be something big to stop all the power. Check for end shake and freedom of the complete train. Have you checked the mainspring. Fault finding can be time consuming. You might like to start from the beginning again.
37 minutes ago, oldhippy said:
Great feedback thanks. Please see below.
All,
thank you so much for your input. It's amazing how just talking about these things helps.
Can I just make a schoolboy correction to my own notes so far on this. The wheel causing the problem is the fourth wheel (220) not the third as I have been saying previously. I have no idea why I said 3rd when it is as plain as the nose on my face 😞
Nicklesilver - you will be pleased to hear you hit the jackpot. Who ever had serviced this last time had put the fourth wheel in upside down. Putting it in the right way up gives plenty of clearance from the intermediate wheel and it runs like a dream 🙂
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
