I‘m going to replace the balance staff of a Russian pocket watch (Molnia 3602). Because it is the first time I purchase a balance staff as a spare part I am not sure about the finishing quality to be expected. Here are some pictures from what I got (ebay, „NOS“). Is this a decent quality for such an item or is it chunk? Your educated comments are highly appreciated.
Edited by Kalanag
  • Kalanag changed the title to Balance staff: is this a decent quality?
This one has never been riveted and used, but the spare parts latest production in post USSR Russia was on lo level of quality. You can burnish the pivots a little after riveting the staff and that's all.
  • Thanks 2
The hub looks a bit rough and the pivot doesn't seem particularly polished but that might just be because the photographer seems to have taken the picture with a potato 🥔😉 . The rivet still looks like it has its shape though.
8 hours ago, oldhippy said:
Russian watch movements/parts in the 70'S & 80'S were not good, they were as rough as a Badgers Ass
I love your example 😄
Old Hippy glad your still around the forum's 🙂 Ive been following your posts since Mark Lovicks first videos.
On 12/16/2023 at 5:02 PM, CYCLOPS said:
you should be able to use after clean-up in lathe as long as the hub fits the balance wheel.....
Meanwhile I found some time to investigate the dimensions of the new staff.
- The pivots fit the jewel holes
- The end shake is fine
- The wheel hub fits the wheel diameter
BUT
- The double roller ID is 0,2mm smaller than the staff‘s OD (0,4 vs. 0,6mm) 🤨
Not having a lathe, what would you folks do?
Edited by Kalanag
BUT
Jacot ?
5 hours ago, Kalanag said:
I should have mentioned that I don‘t have a Jacot tool.
Ronda catalog is showing the roller table diameter on staff as 56 maybe roller is too small . Could you measure on a reamer where you need to be with the size ? Stop short and finish with  a smoothing broach.  Reducing the staff would feel safer for me and normally easier to replace if things go wrong .
Well, there seems to be no other option than purchasing a reamer that I will never need again. I‘m not happy with this idea (yet).
Can a cutting broach do the job?
Well I’ll throw tuppence in the pot, the knowledgeable folks will hopefully chime in. A cutting broach is basically a reamer with a taper, I would think this would be what you would want for this but I may be wrong. A reamer is parallel and would be more for making a true hole. Saying that I think there are also tapered reamers kicking about for things like morse tapers.
Tom
Yes, of course. And You can make one from sewing needle on bench grinder. The roller is made of brass and is easy to cut
I think that is what nev was meaning, reamer just being another term. I wouldn't be too happy either.
Do you have smoothing broaches that you can mark up the diameter on, so you have a gauge to work to. I do this when opening up a barrel hole so i know when to stop.
4 minutes ago, nevenbekriev said:
Yes, my english doesn't make difference between reamer and cutting broach. I try to improve it here...
Its ok nev those 2 terms are more or less interchangeable where ever you come from.  Reamers are often associated with their use in jewelling tools but some people also do call them broaches . Broaching and reaming mean the same, to open up a hole. Broaching a subject would be to open up a discussion usually a difficult one.
Thank you guys! I will make up a sewing needle or smoothing broach and widen the roller hole with this cutting tool.
Edited by Kalanag
the roller or staff needs to have some taper to fit tight, you will use tapered reamers again and again in the future I'm sure, I don't know how you will hold the roller to do this maybe a pinvise.....be careful not to remove too much and hopefully the hole will not get out of round
Got this set of carb jet broaches (0,4 - 1,6mm) for just €9,- (shipping included). They worked well for the cutting. After finishing with a smoothing broach the result is fine 🙂
Edited by Kalanag
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
