Barrel sound issue
vivat
Hi everyone. Today bumped into a problem with a noise coming from the barrel spring. I wounded them 30 times and after this I heard a sound of spring slipping. It was a short sound. Watch is still running, but on the contrary I took a watch with the same mechanism (eta 2824) and they had no sound even after 40-45 times beein wound. Do you know anything about it ? You will really help us because this is the second time facing this problem, previous time we just replaced the barrel...
(The watch I'm working with is a hamilton khaki with ETA 2824 mvmnt. It was badly used, plenty of dents and scratches. And the dial holders are both broken)
8 hours ago, RichardHarris123 said:
Did you put breaking grease on the barrel wall?
Yep
6 hours ago, Kalanag said:
Last time I had this issue the bridle was bent and out of shape. Did you install a new mainspring?
You mean the part where the spring splits ?
5 hours ago, Nucejoe said:
 How long does it run after the mainspring slips, if its comparable with nominal power reserve its OK, if its not barrel must be openned and checked.
Didn't check the time it run after yet. But the spring seems okey. I'll make a photo today
Yep! The end of the mainspring works like the brake pad of a drum brake and the bridle provides the braking pressure by its tension/curvature.
Edited by Kalanag
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
