By HectorLooi · Posted
I find that the most airtight bottles for volatile solvents those with ground glass stoppers. I got some for my clinic over 30 yrs ago. Somehow over the years, I am left with only two. But it keeps acetone and xylene very well. Maybe I should go down to that quaint little dental supply shop and see if they have any hiding in some forgotten corner. -
You guys are great. first, i was wrongly looking up the invicta watch model instead of the movement number. second, i didn't think to look on alliexpress, but there they are, both the spring and the jewel. i better order some extra in case they fly away again. thanks guys.
When I get home I'll look at my packaging again, see if I can recall where I got the WA80. I took it out just yesterday and it was a split bridle.
Watch accessories original suitable for Seiko 7009 7S26 NH35 movement shock absorber spring shock drag bowl shock stone https://a.aliexpress.com/_m08nrxd Have you tried Aliexpress? -
By SwissSeiko · Posted
The taper is pretty negligible. You would reverse the jewel setting in the lathe, and grind again from the opposite side, to counter the taper if it was too much. I haven't tested as far as amplitude gains for either one, or if it's a detriment to not reverse the jewel and regrind from the other side. I'm usually taking off very little, and the burnisher conforms to the jewel surface, so I don't think it makes a ton of difference, but it's a very good point to bring up!
