The next tool on my list is a rotary tool to fix a couple of scratched up crystals.  I've been reading up on watch forums on what tool people use and I see a lot of people use Dremel and Proxxon rotary tools (Did you guys see their mini lathes?  Wow!!).  However, I see that their minimum speeds are 2,000 rpm or so.  Isn't this too much for polishing?  No room for error?  I was looking at something like a Grobet rotary rool (See here) but they do not have specs for lowest speed on their web site.  However, similar tools on Amazon go down to 500 rpm.  Does anybody know if the Grobet goes down to 500 rpm as well?  Wouldn't this speed be better and more forgiving for polishing plexiglass crystals?
thank you
claudio
That looks like a Chinese made Foredom motor. If it is a Chinese made foot pedal, you will have problems with it in about a month's time.
But no big issue as you can build your own benchtop speed control quite easily.
The Chinese made motors are pretty good too. I've been using one for the last 6 months.
I think the electronic foot pedals for sewing machines may work as a substitute but it would require a bit of rewiring. The problem with the Chinese Foredom pedal is that the potentiometer has a very short travel of about 1 cm only. The sewing machine pedal has a potentiometer at least twice as long.
Flexshaft motors can go down to quite a low speed but it wouldn't have much torque at these speeds.
Polishing is a lot of trial and error. The required speed depends on the material being polished, the polishing compound used and the type of polishing tool used. (eg. Silicone rubber abrasives, soft felt, hard felt, wool mop, muslin mop, etc)
The amount of pressure used also depends on the above variables. Some require high pressure, others require a light touch.
It's a science as well as an art. Have fun! 😉
I haven't had the best of experiences with a rotary tool for polishing.
I've had a lot more success using a dedicated polishing machine so I'd recommend that.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
