Looks like someone really squeezed the lugs down on this guy. At the case the lugs are 18mm apart. At the ends they're 16 and 15.5mm.
Before I snap them off trying to fix it, is this something I'd be better off bringing to a local jeweler instead, or can it safely be done at home?
34 minutes ago, oldhippy said:
Do you know what the case is made of?
Looks like brass from the inside.
30 minutes ago, RichardHarris123 said:
How are lungs held on? Are they soldered?  Heat would help but if soldered too much heat would melt the solder.
I haven't a clue. I was thinking heat, but I'm also thinking discretion may be the better part of valor here. I'll have a chat with my local jeweler this week and let you know what he has to say.
I normally just bend them back to specs by eye with soft-jawed pliers, sometimes the area where the lug is attached has enough material to also grab and that would take the pressure off of the solder joint, I have also seen a spreader used.....good luck and Happy New Year
My jeweler gave me the same advice. He said he'd just do the same thing I could do at home.
So I put some tape on my smooth-jaw pliers and gently started bending. I got them just open enough for an 18mm strap.
After some careful reshaping of the hour hand, some crystal struggles, and a little more lug tweaking, it sure looks nice on my wrist.
I had a strange thought strike me that maybe the lugs were designed to be tapered in, but then on closer inspection of the picture they seem to be uneven and not a deliberate designed look, just to be sure I just looked around the web and it seems you were 100% right and they should be parallel:
Great work!
Oh weird, your post just showed up for me!
I also had the same thought as you, but luckily I have that other President case, and the lugs are aggressively parallel.
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
