I've never seen this arrangement. Looks like the crystal seals against this steel retaining ring with a gasket, but I don't see how to remove the ring.
I tried pushing on the crystal from the outside, but it didn't budge, and it seems like a bad idea. Prying from the inside with hand levers seems like a bad idea, too.
It seems like it should just fall out, but no such luck.
Before I ruin something, does anyone know the right way to do this?
According to the Seiko casing guide you do just push down on the crystal from the top.
I believe that someone else had the same issue fairly recently so a search may come up with something.
I did give that a go through Google without any luck. Turns out the forum search was the better choice this time and I found the thread.
That was it! It came out with a medium scary POP, but it came out safely.
So now I have to find the gaskets. I found a casing guide with the part numbers:
Caseback: FA3100B
Crown & stem: OJ0060B
Glass: 0B3005B
but I haven't been able to find specs on these. I think at least the glass gasket started out as an o-ring, which I have an assortment of. As well as stem o-rings.
Is there a place to cross reference the numbers to dimensions/shapes reliably?
Edit for anyone coming here looking for gasket part numbers for their 6106-5549:
Caseback: FA3100B: square profile, 0.6mm width, 31mm inner diameter.
Crown&stem: DJ0060B: D-shaped profile, 0.8mm thick, 0.6mm ID.
Crystal: OB3005B: O-ring profile, 0.75mm thick, 30.05mm ID.
Found it at Seikoworldtime.com! Wow what a tremendous resource.
Edited by ManSkirtBrew
Well, I got the original gaskets, and I can't get the crystal gasket to fit properly.
There's a little ridge around the crystal, but it's not deep enough to hold the o-ring in place, which seems to need a little stretching to fit properly.
I'm dying to wear this guy, so I put the flat gasket that came out back on, and it's a perfect fit.
And after an embarrassing time assembling the crystal, gasket, and retaining ring in the wrong order, It's back together and running again. What a handsome watch!
Image_20240110_2237531421093674362560263.thumb.jpg.9a9ba01e854f8c38f0d165687a1e0c74.jpg
You know what...I think I got the caseback and crystal gaskets reversed. That would make so much more sense and I'm an idiot. Back soon.
Okay, definitely got my wires crossed and had it backwards. But that brings up a new issue.
FA3100B is supposed to sit around the ridge on the crystal, but it's too big. It doesn't even fit inside the case.
I measured the crystal, and it's 30mm. What the heck?
Well, maybe not. The 1978 Seiko casing guide confirms the o-ring is supposed to go under the crystal. But looking at the crystal and caseback (and the crystal gasket that came out) it really should logically be the other way around.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
