Advice on cuckoo clock escape wheel
Jack1845
This is my first post. I have undertaken to service/repair two family heirloom clocks. One, an Ansonia crystal regulator,  is running  and looking great after cleaning and oiling. The other, a cuckoo clock with a 1908 patented Eduard Heer movement,  has a broken escape wheel tooth. Unfortunately I missed the problem and discovered it on reassembly.
 I need advice on how to proceed as the actual repair is beyond my ability. Is it likely to find a replacement part or perhaps a parts movement? As an alternative is there someone who could repair the escape wheel?
any advice would be greatly appreciated as it is a beautiful clock and a family heirloom.
The movement is marked DRGM 329239. An internet source listed the patent holder was Eduard Heer on 1/18/08. Seems likely that he was a relative of Hubert Heer. There is no indication of what the patent was for so many parts may be the same between the Hubert and Eduard Heer movements. Just a speculative possibility.
Thanks for your reply and any additional thoughts you may have.
I am located in the US.
here are a couple of photos of the movement after a quick bath to see what I was working with.  It must have been broken early in its life as  there does not appear to be any discernible wear. I don’t know the earliest history of the clock but it has been in storage for at least 75 years.
A qualified clock maker can cut and insert a piece of brass and shape it to size to make it complete or the other alternative is to cut a complete new escape wheel, but he will have to match the old brass to make a really good job.  On close inspection it looks like cast brass so it should never be cleaned in any ultrasonic cleaning tank, it must be cleaned by hand.
Hi. It would be difficult to estimate as they would very much quote different prices.  I have repaired wheels by cutting out the bad section and soldering in a new bit then re cutting the teeth. Time consuming. My method was to scan copy the old wheel as a pattern and stick it over the old wheel then cut the profile in the rough and file /stone it ti its final shape. With an escape wheel although the gaps are bigger than a conventional wheel it will need better precision and finish so as not to get the anchor mislocking.
1 hour ago, Jack1845 said:
Thanks  for for your replies. It would be a shame to leave such an interesting old clock banished to the attic. I expect such precision work would be expensive. Any rough idea  of  the price I could expect?
Take it to a clock maker and ask for an estimate and make sure the work is done on the premises, what guarantee he provides such as how long and how long will the work take.
Hi there, if no reasonable decision closer to You, I will try to find time to make new table for the wheel and send it by post.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
