17 hours ago, Neverenoughwatches said:
You have the left one yes ? Is there any evidence of the right thread hole ever  being used ?   It is possible the right jewel was swapped but the pivot would need to match the new jewel. Inspection of the pivot heights should give clues, is the top pivot hanging out or low in the jewel ?
Hi, yes I have the left one. The picture doesn’t really show it but the left one is flat and the right one has an oil sink. The threaded hole on the right doesn’t seem to have ever been used so I suppose it’s always been this way. I noticed a couple of coils on the balance spring were stuck together (probably me oiling the pallet stones poorly) so I re cleaned everything and it is now working!! Thank to you all I am now aware that even if there is a machining detail and threaded hole it doesn’t mean something was ever fitted!
Haven't read all posts on this topic in detail, but anyway, if the goal is to determine if a cap jewel is missing I would start having a look at the shape of the pivot as I'm under the impression that it would always(?) be conical for a jewel with a cap as illustrated and explained by @Jon.
Edited by VWatchie
Thanks watchie,  i did read that explanation from Jon an accurate way to determine if the set up is correct. Mine was from an experience 6 months ago of a missing endpiece plate, the top pivot didn't reach the top jewel. I had a big selection of endpieces and just needed to reposition the cap in the plate.
1 hour ago, Burruz said:
The threaded hole on the right doesn’t seem to have ever been used .
The threads might have shown some brass surface where the nickle was scrubbed out from the screw.
cap jewels add to the jewel count which at one time was important from a selling standpoint, higher grade movements have the better shaped pivots which also add to the jewel count....
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
