I am basically done restoring my dad‘s Tissot, but I had all kinds of trouble with cleaning and replacing the balance end stones.
i had one set ping away to be lost forever… Luckily I had a parts movement and could replace them.
This seems to be a major area, where a microscope is practically a must, but I am really interested in some help in techniques to use for cleaning, replacing, and also where I can buy the jewels “separately”
I also had trouble with the other set where the balance wheel would speed up, and then slow down, and then speed up again, so that the timegrapher could not keep track of it
Hi Jeremy,  firstly pinged parts are not always lost forever. There are tricks to aid recovery of them, for metal a magnet , for jewels a uv torch works well. Finding lost parts is the king of all solutions to this problem. Next a microscope makes life easier for lots of service and repair techniques. To follow on for me i hate losing cap jewels they can be a total pain to find, my solutions are to minimise the risk of loss and to have a backup plan for replacing them if they cant be found. Unless you are a well skilled pro or long time amateur using tweezers to move jewels always presents a risk. Many use a method of stick to rather than grasp hold of, rodico or something similar over tweezers. Personally i use a retractable pencil with a pegwood insert instead of lead. The pegwood has a hole drilled at the tip and white blutack pushed into the hole. Theres a post somewhere with a picture. Seems to stick and hold really well, when the jewel is returned home any residue from the tack is dabbed or polished off. I never put them in a cleaning machine, i like to keep them within my sight. Remove pop them in seperate mini glass jars of ipa, when ready to replace ( one of the last assembly tasks ) take out of the cleaning jar, clean and polish on watch paper, buff with chamois, oil and put back in their relative positions. A good trick is a cove proflie cut in the end of pegwood, this then encapsulates the jewel so you can polish and buff its flat side safely. Some use a leather buff stick on top of the jewel, i prefer not to lose sight of the jewel, they have a habit of vanishing into thin air. For replacement i just have a self sorted selection of different size caps, you need a good accurate bench micrometer to do this. And lastly are the newly installed cap jewel right way round, flat side facing in ?  The stop starting could be any friction related issue and just coincidental with the jewel change, or you did something without realising during that work  🥵
At 9:21 I clean a cap jewel with watchmaker tissue IPA and a jewel picker
At 3:22 cat invades the workbench. The only highlight of this video. The title of the video is "Servicing an ugly watch" in Finnish.
Edited by Malocchio
15 minutes ago, JeremyLaurenson said:
Magnets! Eek!
Well, @Neverenoughwatches it worked! Found the spring-in-a-haystack
Now I just have the cap jewel of the balance endstone to find... I may have to settle for letting it enjoy it's journey
Cheap uv torches are about a fiver, turn off the lights and go looking for little ruby glinting. A found ruby is one extra in the stockpile. Any children or grandchildren that can be deployed on recon missions ?
Argh! Another one got away while I was specifically practicing handling them.
It seems that some UV lights are better than others. Does anyone have an amazon (preferably US) recommendation for a big ole honking UV flashlight that lights up jewels well?
One of mine is pretty blah while a smaller one thats attached to a laser pointer as a novelty seems to light them up better.
Thanks in advance
J
Found it! But I still need that recommendation.
You get better at not pinging parts over time. Microscope helps tons.
I clean cap jewels by placing them on a piece of watchpaper, folding it over, and rubbing it around with my finger. Then flip it and do it twice. It usually stays with your finger, and you want to get both sides. This is quick, easy, requires no weird tools, and the paper keeps the jewel from getting away. Just gotta be careful not to crinkle the paper itself, as that can be a flinging mechanism.
I once spent the better part of an evening searching for a click spring or some such. As I was throwing in the towel, I took off my glasses to rub my eyes or something, and there it was on the INSIDE of one of the lenses! I was looking right at it the entire time! Right in front of my face. Not right UNDER my nose, per se, but right nose adjacent.
  • Haha 3
I would claim to find them in the strangest of places. Once in the tub while having a bath, god knows where it was hiding about my person.
  • Haha 3
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
