7 hours ago, JohnR725 said:
Out of curiosity what do you mean by you've tried and failed?
I contacted them by email, trying to re-up, and it went nowhere, several times. Mind you, I was doing Ebay transactions before the 21st century- not for lack of web savvy on my part.
Edited by nickelsilver
10 minutes ago, RichardHarris123 said:
Have you forgotten the  secret handshake?  Hehe.
Lol,  2 of my customers are free Masons, one of them is a master of the lodge. I asked him about the cloak and dagger stuff, he just laughed 😅
Laughter is because he doesn't want to tell you the secrets you're not at a high enough level yet.
He tried to lead me off the scent " its all about charity work and looking after each other Richard " he said . 🤔 yeah ok 😅
  • 7 months later...
Whilst searching for replacement oils for Rolex lubricants I stumbled across a post by @JohnR725 where he linked to a copy of the AWCI publication that I had not seen before (the August 2012 issue). An interesting article describes Rolex lubricants by comparing their properties with those of Moebius equivalent lubricants. If you don't want to read the article, here is what I came up with (which I take no responsibility for):
Rolex MR4    -> Moebius 9501 or Moebius 9504
Rolex LR2    -> Moebius 9415
Rolex TEPA    -> Klüber P125 or Moebius Glissalube A 8213 (Brass barrel)
I haven't found an alternative for Moebius 9103 (HP-1000) recommended by Rolex calibre 3135. Perhaps HP-1300 would do, or what do you think?
Anyway, the reason I am writing this post is that in the process I found another 37 copies of AWCI's publication from January 2010 to January 2013. I have saved all of these on my OneDrive and you can find the link in the first post in this thread.
Have fun!
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
