I bought this watch in 2001. It was my very first "high end" watch. I still wear it regularly.
I've had the opportunity to upgrade it to a newer version, but have not had the heart to part with it. I hope to pass it on to one of my sons in due time.
I love the Submariners, and Seadweller, but they are slightly too small for my 8.5" wrists, so I ended up with a Ceramic Seadweller 4000, which is slightly bigger, and looks much better on my wrist.
I know. I've been using 42-44mm watches for the most part, and the 40mm SD feels a bit small, and my wrist is barely 7.5" I can't imagine what it will look like on such larger wrists.
Nice watch, giving it to "one" of your sons may cause problems!
I know. I think this one will go to my first born. I have a SuperOcean and a Speed Master for the other 2.
I just love Rolex the build quality & style. The 4000 is very nice but I have a small wrist so I wear all the time a Submariner.
Yes, the quality is simple fantastic. Of all my watches, the SD keeps the most accurate time. Love them.
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
