9 minutes ago, rehajm said:
Here's two for inspection...
...part of the challenge is there were so many variants- replacements and originals. What's the 'standard' IWC dial I wonder?
The DDs where made and issued towards the end of the war, and the production numbers seem fairly strick and reasonably accurate though certain brand figures are approximated. Because of the war i would assume the orders were taken and received within a short space of time and not repeated with the war coming to an end within a year . Omega being Omega we would think are consistent with quality and accuracy so not much would change. These two dials look quite different the most obvious being the pregnant 4.  But who knows what they did, the ATPs vary considerably from brand to brand, within the same brand some manufacturers made a few variations .
My understanding is many were trickled out to the public after they weren’t needed or still went to troops around the world, not all if them bearing foreign service markings. So yes, as with ATP, variants likely emerged- which IWC dial is ‘correct’ for example?
…and yes I do tend to agree with your analysis- the older patina dial is from a watch that looks like DD to me and the second one is…something else. But what 🧐?
Edited by rehajm
I've also read that before, Bravingtons retailers were asked to sell them along with the no longer used ATP.  One brand that eventually replaced them was Mellor's Cabot watch in thecesrly 70s.  Just looked at the IWC, 3 different variants, maybe they are all genuine but only one is the original design. The pattern may have changed once or twice as the original stock ran out as damaged watches needed replacement dials.
Just a later pattern ? maybe the watches lasted longer than expected so dial production had to be re-started now and then. The dials might have aslo been outsourced to different dial makers over the years as more dials were needed.  A hundred from here one year and a hundred from there another year. I wonder how much degrade the lume has when its stored on a shelf in the dark unactivated ?
Wow. l was just after a few funny stories but we got treated to the cold war space race and a brilliant analysis of wartime Omega www . You guys love to ramble - better than the brilliant Karl Schlapp on Chronoglide. More horror pictures please. By the way the Omega 30T with the dimples also had some paper shims. Desperate. Needless to say the expensive overcoil balance spring had been damaged and needed a sweaty days reshape. All running great now. The alumium case is scary fragile - why did they use Al ?
Aluminium case ?
12 minutes ago, hofnerpres said:
Photos as promised. The movement number date checks out as 1939 ish.
I dont know what that is. Its not a variation i have seen.
Ah a pilot's watch.
Don’t get us started 😂…to be fair we tend to get back on topic…eventually 😐
Edited by rehajm
Ramble away - I'm still battling trying to get that Breguet overcoil at the correct height - getting enough clearance and allowing for a little endshake is a real challenge. The microscope is no good at looking sideways.
Yes I know I can get a decent view if you hold the movement sideways. My problem was getting things in focus - with a 0.5 Barlow lens on my Amscope it's just beyond the zoom limit. Just tried it without and Bingo - the working range is close but the image double the size so will do nicely for balance fiddling. There will now be an intermission for Irish Stew....
Edited by hofnerpres
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
