...just getting started with watch repair, with a family heirloom 1927-ish Elgin pocket watch. I think it might be a lost cause, but I'm learning as I go.
Hi there @timrod you are brave starting with a family heirloom as one of your first watches. I would advise you to practice on some others, that don't hold any sentimental value to you, until you get enough confidence and experience under your belt before risking something that means something to you. Either way there are loads of people here very eager to help and guide.
  • 4 weeks later...
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
