Hi all, I wonder if anyone may be able to help with identifying / sourcing a balance staff for a 50s Seiko Marvel please?
I don’t believe that there is a calibre number for this movement, it is known as the Marvel. It is an 11.5 ligne movement. The Lord Marvel is a descendant but not interchangeably so.  I managed to acquire a Bestfit 1870 staff which is a fair bit too short but does have a lot of features going for it. The table height appears good as does the roller seat diameter and most probably the collet. It is a friction fit type staff and my balance was marginally too loose on it to be secure. I will upload a pic with measurements plus Bestfit and Ronda keys. I suspect the correct staff is at least 0.1/0.2mm longer than the 1870. I do have a Ronda staff for a later model, I forget which, that I might be able to remove the rivet thus adapting it to a friction fit to see if that will work. As you can imagine if somebody is familiar with these early Seikos and can jump in with an educated “Yep you need a blah blah blah for that one” it would be a much better outcome than a modified staff. I am starting to suspect that fate of this watch is to be dismantled and parts sold to help prevent further watches from a similar demise. But as a last resort I kindly ask if anyone is familiar with these and if they have any leads.
One more point to note there is no semi circlular cut out by the balance at 10:00 ish nor are there two studs visible on the balance cock on my movement unlike some of the similar looking movements I have come across during my research.
Thank you for your time.
2 hours ago, clockboy said:
Welcome to the forum, enjoy. I use balancestaffs.com.
https://www.balancestaffs.com/seiko.php
Thanks for your reply. Unfortunately I don’t think Seiko were on Ronda’s radar at the time. Bestfit, Ronda and DCN do not appear to have manufactured a staff for this calibre. I would suspect I’m looking for a Seikosha manufactured part. Balancestaffs.com is a great site and a lot more user friendly than the Mid 60s manuals. Although in favour of the manuals, when comparing prints of 50s to 60s manuals you get to see how Ronda re-used their codes as staffs went obsolete. And of course you can’t beat the smell of vintage paper!
7 hours ago, rustyscoot said:
Seiko Marvel
the problem with the parts books like bestfit is the watch had to be made in sufficient quantities exported from the country of origin that somebody would be concerned about having a spare parts available for it.
then for instance if you had the bestfit book and look up Seiko they do actually list the named calibers just not yours. Then what shouldn't do is go find the section of balance staffs listed by size and see if you can find the staff that's very close to what you're looking for. Seeing as how this was their first in-house movement it's hard to tell whether any of the parts would migrate to other watches or whether everything was unique on this watch.
Then what's interesting about yours is the spring holding in the jewel for the balance is different than what I'm seeing. Neither seeing some with no spring at all or Seiko's standard spring. Which there very proud of and they put that on the dial. None of which helps you get a balance staff though.
oh and here's a bit of the history on your watch
https://corporate.epson/en/about/history/milestone-products/1956-6-seiko-marvel.html
You make a good point. The calibres listed in Bestfit / Ronda are 60s calibres. The world still has an affinity to the mid 60s divers suggesting Seiko became familiar to the world at that time. Hence why I’m hoping someone has knowledge of Seikosha parts rather than shooting blind modifying a Ronda 5347 to “fit”.
Thank you for the link.
I guess You are not sure about the exact lenght of the staff needed? You have only the old one which is broken so You can not measure it?
There is simple way to exactly measure the needed lenght. I will explain if needed. Have in mind, that in shock proof movement staffs there are a lot more dimensions to be compared than this A,B,C,D before making conclusion that the staff will fit. That's why it is making new staff much more secure choice than finding similar one and trying to modigy it. Unless it is bigger in all sizes and used as a stock material...
On 1/26/2024 at 5:49 AM, Nucejoe said:
An article on lord marvel which also covers the exact variant you have.
https://adventuresinamateurwatchfettling.com/2020/04/04/origin-of-the-species-a-seiko-marvel-from-1956/
one of the minor annoyances with the article is he gets a balance complete from  cousins and conveniently doesn't tell us which one it is. I always find it interesting rewrite a fairly detailed article with lots of pictures of naked movements and gears and then you just don't tell us the actual part numbers just in case somebody might like to follow in your footsteps
actually I'm not sure about the dimensions he gave us dimensions of the image up above and the helpful link to the article above is it's helpful because we had no part numbers we don't have anything to reference the other Seiko staff that is mentioned with vintage Seiko's is 2009 and it's much longer than his dimensions which is why I'm not sure about his dimensions.
so here's where to get an interesting problem the size the 1870 still longer than the suggested size in the measurement.
which possibly says the 2009 is the correct size staff. As it's the recommended staff for most not all but most of the vintage Seiko's at that time with shock protection with 1870 is for non-shock protected.
But those dimensions are still considerably longer then what he has for his suggested staff length.
The 2009 has a rivet and is not a friction fit. Plus the roller seat and collet diameters are too small and therefore it can not be the correct staff.
It is probably closer in length though. With the 1870 measuring 317 and me estimating it to be a tenth too short.
Right,
 So far as I know which is not much, all Seiko Marvels were powered by calib 5740  with three variants A, B and C .
Seiko Marvel 5740A  which beat 18000 per/ hour.
Seiko Marvel 5740B which beat 21600 per/ hour.
Seiko Marvel 5740C   which beat 36000 per/ hour.
Just by the looks of bridge layout I say this is 5740A, to make sure OP can count gear teeth, pinion leaves to calculate the beat.
I don't know which staff fits which calib.
Hope this helps
I would advice You to use micrometer to measure the distance between tops of the cap jewels and subtract the hights of the both cap jewels from the result. Thus You will have the correct staff lenght.
On 1/28/2024 at 3:36 PM, Nucejoe said:
Right,
Hope this helps
They are Lord Marvel calibres from a few years later. They are descendants of this calibre but are not interchangeable.
Thank you all for your input. It seems the answer lies with the Moeris 10.5’’’ staff with this particular calibre. I will need to slightly reduce the thickness of the friction fit / collet seat.
  • 1 year later...
I’m working on one that looks exactly the same movement as this.  I need a replacement cannon pinion and hour wheel.  Did you have any luck identifying the exact movement number?  Mine is stamped 59 on the dial side of the movement, presumably the year of manufacture.
Edited by MikeEll
Looks like a 560
Edit
Just realised being 17 Jewel it will be the Laurel.
Double Edit
Thought I better point out that the Pinion is the same as the 560 but the Wheel would be a 255.392 on the Laurel
560 Parts List.pdf
Edited by AndyGSi
9 minutes ago, MikeEll said:
I saw this one but it looks a much older design
Are you getting mixed up with the old pocket watch Laurel.
Cousins have the Pinion you're looking for but the Wheel is a little more difficult but maybe worth
a message to this eBay seller to confirm which version of the Laurel these parts are for.
https://www.ebay.co.uk/itm/273801397240?var=573486636384
Edit
You can see from the Emmy link that the Laurel shown shares parts with the 560 among others.
Edited by AndyGSi
Possibly yeah, I was just looking for a picture of a Laurel movement to confirm its the same.  The 506 is very similar obviously, but I cant find a picture of a lautel movement that matches mine.
Cousins doesn't have a photo but sometimes eyes on helps confirm...
...I'm dealing with one of these old Seikos right now and learning the differences in sourcing parts for them- they don't exactly follow Swiss protocols do they? Mine's a banana movement that needs a staff and I've just discovered the 10A vs 'New 10A' problem- who knew?
...yah, that bridge is certainly different but the evidence parts were shared...helps, I suppose? 🤣...
Edited by rehajm
Here's an example of a Laurel.
What dial is on the movement you're looking at?
https://www.ebay.co.uk/itm/286047108466?chn=ps&_ul=GB&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=286047108466&targetid=2406300041925&device=c&mktype=pla&googleloc=9046649&poi=&campaignid=21697381820&mkgroupid=171410935890&rlsatarget=pla-2406300041925&abcId=10027101&merchantid=662079581&gad_source=1&gclid=Cj0KCQjws-S-BhD2ARIsALssG0aTy5pkLWXOGttAxt6CmohtaVQ13cTPNWbXCuBAy4Hm7ppNR1IjVgYaAlyYEALw_wcB
Edit
This is a better example.
https://www.birthyearwatches.com/product/1960-seiko-laurel/
Edited by AndyGSi
Andy, the first link looks different to mine, the escape wheel jewel mounting is different.  The second link showing the 1960 Seiko Laurel looks pretty close, although this one has a different balance shock protection than mine.  Just grabbing an image of my dial.
I think thats M14017 at the base of the dial.
Edited by MikeEll
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
