26 minutes ago, MikeEll said:
Andy, the first link looks different to mine, the escape wheel jewel mounting is different.  The second link showing the 1960 Seiko Laurel looks pretty close, although this one has a different balance shock protection than mine.  Just grabbing an image of my dial.
I think thats M14017 at the base of the dial.
I wrongly presumed the dial was blank and that's why you were asking the question.
This now raises the question as to which is the correct Hour Wheel
255.392 or 271.570
yeah, thanks Andy.  Hope I'm not coming across as ungrateful, I really appreciate the help.  Just that I've been burned before when I've assumed movements look the same 🙂
...and sorry for inserting myself into this thread but for posterity be warned, the lack of reliable information on these older Seikos is a bit maddening. When the movements don't have hallmarks but sometimes have caliber numbers and sometimes shikona and sometimes one name used for more than one movement...🤒...
Bestfit tells the story- just look at those calibers...
The fact it has a Marvel Dial and a Marvel Movement means it's a Marvel.
The question is that information on the original Marvels is none existent
and only information on the subsequent movements is available.
I've got a 271.570 Hour Wheel somewhere so will find it and see how it compares to yours.
Nothing to be sorry about. It's an open forum and anyone can comment.
On 3/19/2025 at 9:11 AM, AndyGSi said:
Hour Wheel 271.570 6mm Diameter with a 1.5mm Boss and 1.35mm High
Cannon Pinion 225.570 2.1mm High
@MikeEll just wondered if you'd had chance to compare these yet?
The canon pinion looks the same, and the hour wheel is very close.  Same number of teeth but 1.40mm height.  I’d say probably the same parts.
I'd say for the price they'd be worth a shot.
