Hi There, this is my first post here. I did some searching around and I apologize if this has already been covered and I was unable to uncover it 🙂
As I said in my into, I've just gotten into the hobby and I have an ST36 movement I'm practicing on. One issue I keep running in to is my tweezers are sticking to the smallest parts. Stuff like the setting level spring screw and / or the pallet fork and pallet fork bridge screws. It doesn't seem to effect the larger stuff. I dont know how to tell if there is a static charge and Im getting some magnetic action? I've wiped my tools down with IPA several times but I dont know how else to proceed.
Thanks ahead of time for any suggestions.
18 hours ago, levic900rr said:
Hi There, this is my first post where. I did some searching around and I apologize if this has already been covered and I was unable to uncover it 🙂
Do you know what steel your tweezers are made of ?
Great question. They're "stainless" which I know doesn't really tell the whole story. The product details say "Premium Stainless", but I'm embarrassed  to say they're 9 dollar amazon specials ( https://a.co/d/d555t6f ). Perhaps I should have spent more... I just assumed they would wear out quicker than the real premium brands, I never considered that they would be harder to use.
I have cheap ebay tweezers from my first set. I do two things often. Demagnetise and keep them 'dressed', sharpened. The demagnetiser cost me £10. A honing stone cost me £3. that's it.
Press the red button on the magnetiser, Demagnetise the tweezers by lifting them off the base ad going up. Release the red button. Repeat twice.
Dressing. Using my magnifying glasses to confirm what I think I see. Shape and form the points. Dress all four edges and then gently removes burs. Job done.
I use a pair of curved brass tweezers when  working on an expensive watch that might show scratches. These were a massive £3 also. And, I do keep them dressed.
Would I like high end tools. Of course, but to what end would it make my work better and this stage of my learning curve I ask myself?
My standards are getting better by practice, not by high end tools.
This is a great hobby
  • Like 6
Awesome advice, I ordered an inexpensive demagnetiser today. Hoping that does the trick. Otherwise I've been happy with the performance of the set I have. The fit nicely in my hand and I can manipulate the parts well.
Thanks everyone!
well, make sure the inside of the tweezer is clean, goes without saying, I have two types of demagnetizers, one is a coil type that you hold/put inside and push a button to energize then pull it away to remove the magnetism, the other you lay/hold the item on top and push a button and hear a pop, both work as they should but do not put a hairspring in the coil type......
Make sure to demagnetize it several times in several orientations if you are using the cheap little blue one.
When working on a dirty movement, even my bronze tweezers get really sticky after each part it seems. I just stick them in a blob of rodico between parts to get the dirt and old oil off.
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
