Lesson learned - Running American pocket watches uncased
I'm not sure I have any question left here, but want to relate my Captain Ahab story getting this junk Elgin grade 206 7j watch to run. It came to me in a bag of broken watches a relative's acquaintance handed over. The "before" picture hides the fact that all 3 brass wheels were seized together with green corrosion. The case was black, but this I learned right away was just a badly tarnished coin silver. It cleaned up really nicely. It's a type of case I have not encountered before, extending a 6 size movement to more like the a 16 size case with a broad spacer ring.
When disassembling the case, I broke the stem sleeve. It was rusted and brittle. I figured this was unimportant and I would eventually replace it. Though I was surprised to find how much those parts sell for. I expected them to be available by the sackful, but instead sellers want $15-$20 for a single one. I kicked this down the road so I could get the movement to run.
The movement cleaned up okay, and I was able to remove corrosion enough to reuse all but the 4th wheel. It had 5 or 6 teeth that were eaten away not enough to stop the watch, but to send its timekeeping haywire every 45 seconds. I worked on this over several months, replaced some wheels with spares, tuned the escapement to my current skillset. The movement ran, eventually acceptably well. The balance is out of poise I think, based on a 40sec positional delta. I can deal with that when I have a poising tool.
But with the dial and hands installed, it would never keep accurate time. Sometimes it would be good for a day then suddenly lose ten minutes or lose 6 hours. It felt like a cannon pinion problem. I got the tools to tighten the cannon pinion. This didn't help at all. I replaced the center wheel because its arbor was kind of worn. That did not help either. I replaced the cannon pinion entirely with a donor's. It had a positive snap on install and good feel to handsetting but still no change in behavior. I thought maybe the hour wheel was riding up out of mesh with the minute wheel so I tried manipulating and eventually stacking dial washers, no change. I learned how to close the holes in the hands for a firmer fit on the hour wheel & cannon pinion.
I was going to give up on this one when I found someone selling a bag full of stem sleeves for a reasonable amount. I bought them and installed one that fit, planning to sell this watch on and note its fault for someone else to figure out. But after installing that stem sleeve and recasing it, the watch is now keeping time all week without any issues in the motion works.
Why?
Because the keyless works on this type of watch are inverted. The stem must be pushed in and secured by its detent with a stem sleeve to engage the winding mode. Otherwise, its default position under spring tension is to engage the hand setting wheels (in the photo above, that spring is not engaged but that's not the problem). All the while I was trying to get the hands to keep time, it was running uncased and the cannon pinion was therefore driving all the handsetting wheels. It can't do that without slipping occasionally and that was its issue all along. It still isn't perfect, I need to troubleshoot a problem with the spring tension in the keyless works while it actually is engaged in winding mode.
But now it's all together, and will make a nice little desk clock or something once I clean up the dial a bit to hide those cracks. And the next time I work on an American stem wind/stem set watch I will make sure it is cased when I test it out with dial & hands.
  • Like 5
  • 2 months later...
I also just want to add to this topic in case people are searching for info, if you are inserting and removing the winding stem and crown more than a few times, be a aware the the sleeve surrounding the stem by the crown is threaded. so if at the end of your project, you can only wind the watch by pressing in the crown, adjust the sleeve. This confused me for a few days, and I disassembled the watch many times thinking I had an issue with the keyless works.
With pocket watches, if you change cases, you have to adjust the threaded sleeve so that the stem sits proud of the case the correct distance. I started on pocket watches, and found it easier when I moved on the wrist watches as all the keyless work stays together.
Usually in later generation of American pocket watches they have a variety of features to put the watch back in the winding out of the case. This is because they typically sold the movements separate from the case and they needed a way for the watch to run.
Then yes casing issues of American pocket watches can be a challenge because the quantity of sleeves available now are quite a bit less than they once were. Plus often times You need you go to adjust them you find that they been stripped or a mutilated or something else by people who didn't grasp how there supposed to be adjusted.
Then amusingly up until recently you could purchase a brand-new Pocket Watch Sleeve Wrench From cousins now apparently unavailable. But use once you up on eBay all the time.
https://www.cousinsuk.com/sku/details/discontinued-items/p56437
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
